squeaking from springs!
Ok , guys I am not a frequent complainer, but I have a problem with my Eibach springs, which sits on KYB AGX's . I have notice when comming off of 1-2 gears , there is and annoying squeaking noise comming from the front suspension(none from the rear). I have inspected the springs and noticed that the two upper coils are touching. This was determined by visual rust on both coils( a concentric line of rust). No alot , but a small amount.
I have tried the Radioshack wire looms . They worked perfect ,when inserted on the coils. For the first time , since stock setup , I have truly enjoyed take off!( I might sound like an idiot , but that is ok).
Ok , now the squeaking has returned , after only one day, so basicaly I have failed to fix the problem (apparently the wire looms got busted). Now I am out of options. Does anyone have this problem , and any imput on how to fix this minor problem?
Thanks for all of your help , in advance.
Re: squeaking from springs!
Re: Re: squeaking from springs!
Originally posted by mohfo
check the sway bar bushings.
Another thing i was thinking is that Eibach did not spring coated the upper coils with the rubber tubing like they did with the 5th Gen Eibachs, so this might be reason why they are now doing it on the 5th gens. I know this for a fact, because i had both 5th and 4th gEN Eibachs brand new and i saw the differences.
Re: Re: Re: squeaking from springs!
Originally posted by Deven2kStickMax
true and very good point mohfo. so in other words if the sway bar bushings not working well, then there would be more suspension travel, causing the coils to move more right?
Thanks again, oh , I do not have any aftermarket sway bars. How do I know if the current sway bar bushings are worn? Where are thay located?
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
