ECU reset, Screw driver, or Dealership? (differences?)
Old Nov 25, 2002 | 08:11 AM
TonyGotSkilz's Avatar
Hey I've had some starting problems and i've heard that i should have my computer reset by the dealership. I've reset my ecu SEVERAL times by using the screwdriver method, and still had the same problems. So my question is, Whats the difference between the way nissan does it and the screw driver method. I know they use a computer i mean does it actually do anything different? Does it somehow reset it more? is that even possible?
Old Nov 25, 2002 | 08:15 AM
1MAX2NV's Avatar
You should really find out what's the root cause of the problem. Resetting the ECU never "FIX" a problem.
Old Nov 25, 2002 | 09:32 AM
dwapenyi's Avatar
Yeah, fix it. Your computers trying to tell you something's worng. When you reset it, you're just telling the computer to fuhgetaboutit, and it does so obediently. Since the problem is not solved, it comes back.
Instead of resetting, find out the code. Turn the screw all the way clockwise, then turn it back counter-clockwise slowly, while watching the check engine light. At some point, the check engine light will start blinking in morse code. A few long blinks followed by shorts ones. Example: 7 long blinks followed by 5 shorts ones means a code of 0705. Take down those numbers, then reset the computer.
Oh, and sometimes the computer might store 2 codes. Get them all.
DW
Old Nov 25, 2002 | 09:41 AM
Entropy's Avatar
To answer your question... the dealership can't "reset" your ECU any more effectively than the screwdriver method. They might be able to do it without breaking the seal on the reset screw electronically but I think that would be the only advantage.
The important thing, as stated in previous posts, is that you find out what code the ECU is throwing.
Old Nov 25, 2002 | 11:14 AM
nadir_s's Avatar
vicodin ... gift of life
I believe another way to reset your ECU is to disconnect your battery for an hour or so... I'm not sure 100% if this works, but i do it every time i mod my car so that the ECU adjusts to the new flow of air into the engine or whatever. It just compensates by adjusting the air/fuel mixture. And i think the reset on the ECU is just to reset the codes and see if it comes back again.
Old Nov 25, 2002 | 11:18 AM
clee130's Avatar
Like everyone else is saying, pull the code first before resetting the ECU.
And the only difference between resetting it yourself and going to the dealer to resetting it is $75.
Old Nov 25, 2002 | 02:55 PM
Since i was in a rush i didn't explain well enough, thanx for trying but your info was useless <Grin>. No offense really. I already know how to pull the codes thats what i meant when i refered to the screw driver method. Problem is my comp isn't throwing ANY codes. Its fine, my sensors are fine. My problem is with starting the car. I defined it in another thread so i didn't want to do it again. I'm no n00b . I do know how to pull codes i've done it PLENTY of times, and i know how to reset the comp. The reason i was wondering is because someone else said that they had the same problem as me, took it to nissan, and nissan told them (the dealership i mean) that they need reset there computer every 60k miles. He also said that after they reset it, the car started fine, fixing the problem. If that is the case (which doesn't seem right to me either thus me asking) i'd need to take mine in to have the same thing done. But if there is no difference between dealer reset and screw driver reset (The original question i asked) then i don't need to take it to one. Thanx for trying though.
Oh and about the smiles... i just felt like putting some new ones in here
Old May 12, 2023 | 03:27 PM
Shena's Avatar
Reset screwdriver style? That sends a lot of voltage to your computer and fries it. Use a resistor in the future
Old May 12, 2023 | 08:23 PM
JvG's Avatar
JvG
[QUOTE=Shena;9253007]Reset screwdriver style? That sends a lot of voltage to your computer and fries it. Use a resistor in the future[/QUO
Hi. Welcome to the forum.
Notice the posts have dates
You responded to one that's over 20 years old.
Old May 13, 2023 | 12:06 AM
[QUOTE=JvG;9253021]
+1. And I think he's confused on what the "screwdriver" method really means.
matts95max
Apr 23, 2025 10:44 AM
boomerbrian
Oct 31, 2018 10:25 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
