Is geting a b-pipe worth it for a N/A maxima?
I'm strongly considering ordering the budget y-pipe. I've heard that you get what you paid for, but aren't all y-pipes, at least budget and WSP, the same in performance gain? Moreover, I currently have the Frankencar intake with Greddy muffler. I'm not planning to add a S/C or a turbo. Will I lose some low end by getting the b-pipe along with the y-pipe. Is the b-pipe fix offered by WSP a good enough solution?
A b-pipe will give minimal gains on an N/A Max, maybe about 5 HP and most of that comes from removing the restictive S bend and crushed area behind the cat. The bpipe fix removes these two restrictions so it should give nearly the same gains as a full bpipe, but it may be easier to install a full b-pipe instead of trying to cut your stock one and attach it to the b pipefix. A bpipe should not cause any noticable low end loss, at least with a 2.24" one.
The gains from different ypipes are very close so it should not really matter. There where some complaints about the 'bees in a can' sound from some of the early budget mandrel bent Ypipes, I am not sure if this has been fixed, I would do a search and read up on it before I bought one
Re: Is geting a b-pipe worth it for a N/A maxima?
When I first installed my JWT POP, I suffered from torque loss on the low end (like everyone else says). When I replaced my oem exhaust system with Budget's y-pipe, high-flow cat, Budget b-pipe (no resonator) & 2K1 Maxima muffler with 2.5" inlet pipe, I noticed two main changes:
(1) regained lost low-end torque;
(2) significantly more power from 3K to 6K rpm.
I've yet to dyno the car (probably doing it around Feb.) I'm itching to see the HP/TQ curves with the mods.
Thanks all. Does it matter if I go with a 2.25 or a 2.5 b-pipe? If the b-pipe is not to expensive, I may get it from budget as well.
Originally posted by VQdriver
i have the older non mandrel T304 budget ypipe and i'm still very happy with it. it's the same since i got it two summers ago. the courtesy bpipe i have is about 2.25 or 60mm. i'm not exactly sure. it's a little bigger than stock that's for sure, but it's not 3" piping. unless you're going forced induction anything less than 3" should be fine. for the least expensive but 100% effective setup i'd get a budget T304 ypipe, warpspeed alum testpipe, warpspeed alum Bpipe w/ or w/out the resonator, welded to a borla or dynomax muffler. my exhaust is pretty "unique."
Originally posted by 96BLUMAX
I would say go with 2.5". My greddy was only 2.25 and now i notice a little more power with 2.5" and my true straight through muffler.
look up my original post titled "borla, the absolute perfect setup."
My current setup is pretty quiet. I can barely hear the exhaust. All I really hear is the intake at 2K to around 3K RPM. It makes a low growl sound which I like. It can get loud at times while crusing on the highway.
Since you already have an aftermarket muffler with the stock Y and B, everything seems OK now. Once you add the Y pipe, though, your exhaust is going to get loud. That's not to say that the Y is loud, it's the combination of Y and aftermarket muffler that seems to always produce decibels, the kind you don't want. If you want to keep everything NA, I would suggest you maximize your power potential by doing everything, Y, B and muffler. Maybe look into VQ drivers' setup, or replace your muffler with a 5th gen muffler. That way, you get the most power, but not alot of noise either, or nice noises, from your exhaust.
DW
DW
Originally posted by breaux124
I'm going to get a bpipe, but keep my stock muffler. If I get a pipe without a resonator, is it going to make my setup much louder?
I already have a CAI and a Y-pipe.
MAXSE5SPD
Aug 23, 2015 12:06 PM
