View Poll Results: What is going on with my repair job?
The wrong coil pack was changed
80.00%
There is probably more than one bad coil pack
0%
The new coil pack doesn't work
0%
It takes a while for the computer to relearn
0%
You should have bought all 6 and swapped them
20.00%
Voters: 5. You may not vote on this poll
When I replace the faulty coil pack....
Old Nov 28, 2002 | 08:37 AM
FLO_BOY's Avatar
will the problem be eliminated immediately? OR, like other fixes,
it takes a while for the computer to learn about the fix?
Last night I swapped out a new coil pack for one I thought might
be bad, and well, the car is still not working properly....
So, this means one of a few things:
1) I swapped the wrong one.
2) The new one doesn't work.
3) I had more than one faulty coil pack
4) It takes a while for the computer to "relearn".
Thoughts????
Thanks!
FLO_BOY
Old Nov 28, 2002 | 09:42 AM
lan30122's Avatar
How much do the coil cost? where do I buy them at? thanks
Old Nov 28, 2002 | 10:04 AM
Jamsan's Avatar
coils are about $50-60 each, and we have 6 of em...not a cheap thing to go wrong when it does...you can get them at the dealer...
1) could be
2) possible, but not likely
3) did u get a CEL for your troubles? if you had more than one fault pack, it says multiple cylinder misfire...if you didnt get a code, then
4) nope
Old Nov 28, 2002 | 11:07 AM
FLO_BOY's Avatar
Originally posted by Jamsan
4) nope
hey Jamsan,
So, if I swapped the correct one the FIRST time,
the car should act normally, correct?
Thanks,
FLO_BOY
Old Nov 28, 2002 | 11:46 AM
2KxSEx's Avatar
As soon as I swapped my bad coil out, my car started running like it should with no problems from before. So yes, the answere is that your car should run properly as soon as you swap the coil in.
Peace.
Old Nov 28, 2002 | 11:48 AM
Jamsan's Avatar
FLO_BOY's Avatar
Peace.
THANK YOU!!!
just what I was looking for...
FLO_BOY
Old Nov 28, 2002 | 11:56 AM
2KxSEx's Avatar
My pleasure bro.
I've gotta hand it to you Flo, you just don't give up do you? I've watched you fiddle with your problem for at least half a year now. I respect your dedication bro. Good luck once again.
Peace.
Old Nov 28, 2002 | 12:00 PM
FLO_BOY's Avatar
Peace.
Thanks!
Most of my friends tell me -- "Just take it to a mechanic"...and I get
so pi$$ed off!! Everytime I take my car to the dealer (twice now,
and both times different dealers!!!) they give me bogus super-expensive
repairs that wouldn't have solved my problem.
So, I've HAD IT with dealers...and mechanics...with the .org and my
own mechanical abilities, I think I'm as good as some of those con-artists!
Anyhow, thanks again!
FLO_BOY
Old Nov 28, 2002 | 01:57 PM
Max6856's Avatar
i have 6 coils off a 96 maxima .. all work fine... im selling all 6 for 150 + shipping
Old Nov 28, 2002 | 06:51 PM
D1NOnly34's Avatar
Trial and Error, best way.
Old Nov 28, 2002 | 07:05 PM
Jamsan's Avatar
screw it ...just unplug 2 of the sensors to the coil packs and be a 4 banger
Old Nov 28, 2002 | 08:17 PM
D1NOnly34's Avatar
Old Nov 29, 2002 | 07:25 AM
FLO_BOY's Avatar
OK, so I tried the "unplug and omethod...
and, well, EVERY pack I unplugged affected the RPMs, which takes
me back to my other post that when a coil pack goes bad, it only
affects the car sporadically, which makes this method essentially
worthless!
Oh well, I have some more questions on this, and I'll post 'em now.
take care,
FLO_BOY
vingodine
45
May 21, 2016 12:46 PM
tnewbs
Aug 28, 2015 10:15 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Maxboy23
Aug 21, 2015 11:02 AM
