automatic climate control problems
I have a problem with my heater, it started about a week or so ago when my heater all of a sudden started blowing cold air, I have to turn the temperature all the way up before it would start to blow out warm air, it won't even blow hot air at high temps just warm. Anyone know what the cause of the problem could be or have had problems similar to this? I don't want to go to the dealer yet and get charged up the *** to fix this. Sorry I forgot to mention also at odd times the heat works for a little bit at low temps..
Re: automatic climate control problems
Is the temp gauge in your car near the middle when you're not getting the hot air? If not and it read cold, it's probably as tonyg24 said, the thermostat may be stuck open. If the car is running hot, then it could be problems with the water pump impeller needing a replacement water pump. If the gauge is in the correct zone, then I'd look at the heater control valve that diverts coolant to the heater core and at the possibility of a clogged heater core. When is the last time you changed your coolant? If it's been recently, it could be you have and air bubble in the system preventing coolant from going to the heater core. If it's been a while, what is the condition of the coolant? If it's orange or appears to have particulate matter suspended within it, it could be a clogged heater core.
-V
-V
maxfever1987
Sep 6, 2015 06:20 PM
