ES FSB bushing information...
Old Nov 30, 2002 | 12:10 PM
Vyrus's Avatar
Hey guys today I ordered my FSB bushings from Bruce @ www.suspension.com. Not only was he a pleasure to order from, but he really knows his suspensions and can explain to your the benfits and disadvantages of the bushings.
Anyays he verified for me that the grease the ES bushings come with (called "Formula 5") is 100% trailor hitch grease you can pick up from Advanced Auto. Not that you'd need to though, because it comes with the bushings anyways.
He also told me to make some grooved inside the bushings, to hold the grease in. He did a test with 2 bushings on his car, one with grooves he made on the inside, and one with a smooth surface like ES sells them. He told me that after 6 months his one without the grooves was squeaking and dry, and the other wasn't. So to those of you who have yet to buy/install these, make some grooves inside (that don't go out to the edges) so the grease won't squirt out.
He also said that ES doesn't make endlink bushings for the Maxima, and the ones Courtesy sells are generic endlink bushings. He advised against them, because although the design is good they cannot take the wear and people have had many problems with them.
Also I don't know if you guys know this, but he said you don't have to take the FSB off to put the midlink bushings on. He said just take the clamp off, cut the old bushing off, and the new eurethane bushing will stretch enough so you can slide is over the bar. Then all you have to do is put the clamp back on and move to the other side.
And finally as a reference, he said DO NOT by any means put the grease on the outside of the bushing. He said it will only make is sqeak more.
Hope this helps somebody,
-Cyrus
Old Nov 30, 2002 | 01:28 PM
redmaxpa007's Avatar
i SeE what you did therE
Re: ES FSB bushing information...
-Cyrus
keep me posted on this..
Old Nov 30, 2002 | 06:26 PM
trinity000's Avatar
thanks for the info i am doing mine monday night... as well as lower control arm bushings and even though he advised against it endlink bushings... just cause they are meant for another application thatu ses the same size doesn't mean the material is any different nor the stress on them i don't see how they couldn't handle it.
not that i am saying he is wrong just i don't understand his logic or reasoning.
Old Nov 30, 2002 | 07:09 PM
Vyrus's Avatar
Yeah I wasn't quite sure about that either, he just said the endlink bushings were more prone to sqeaking so I stay away. I've got too many sqeaks as it is hehe.
-Cyrus
Old Nov 30, 2002 | 07:10 PM
trinity000's Avatar
lol well i guess i will be on the one to take on the challene of making them quiet.
Old Nov 30, 2002 | 07:24 PM
Vyrus's Avatar
You should do the same thing I said above with these, make grooves inside of them for the grease to stay in (don't extend the grooved to the edges).
-Cyrus
Old Dec 1, 2002 | 05:57 AM
gotta order this stuff for my explorer too..
Old Dec 1, 2002 | 10:09 AM
ericdwong's Avatar
I would take his advice on the end link bushings with a grain of salt. When I ordered my bushings from him bout 2 weeks ago, he said that there were no end link bushings. I then told him about the part # courtesy used and he said that was a body mount bushing but it should work and he had none in stock and he had never heard of it used for the maxima like this b4. For the few bucks it cost to do I'd do them.
Good info on the groove though, Ill have to do this when I put mine in.
Old Dec 2, 2002 | 05:55 AM
95Max's Avatar
I ordered my bushings (bar and endlinks) from him. Yes there is on ES part number but he sent me generic endlinks and no issues.
Old Dec 2, 2002 | 07:34 AM
xHypex's Avatar
I have the ES endlink bushings from Courtesy and have had no squeaks since installing them. I greased them, but there isn't really any room to make grooves on them (they're small).
Let us know how the cut/install method works for the FSB bushings. I've been waiting to put mine on because I haven't had time to take the FSB off.
-hype
Old Dec 8, 2002 | 10:17 AM
Vyrus's Avatar
FSB Bushings Installed...
Got them in the mail and installed them yesterday. It comes in the little ES box with the grease, bushings, and general instructions.
The grooves are really hard to make since the polyeurethane is hard to cut into. I basically used the tip of a screwdriver to make a few indentation lines in each of the bushings. They're not deep, but deep enough to retain a little grease.
As far as the intall, it took me about 1.5 hours. If you've done it before I wouldn't think it would take more than 1 hour. The bad news: you have to take the endlinks off to put the mid-bar ones on. They are held on too tight to the chassis, but once you remove the endlink they whole bar will spring up (be careful, the nut and upper endlink will spring off fast and hard!) on that side. Now you can easily remove the old bushing and install the new one. The hard part is putting tightening the bar again. The bar will not be easy to bend back onto the endlink, but it can be done. I used a 1-foot wrench to pry it down. Put the upper endlink bushing back on and screw it down. Then put the mid-bar bracket on top of the mid-bar bushing again and you're done. If you're fast you can do it in 30 minutes/side, but I took my time since I had no specific instructions.
So far I've definitely noticed an increase in NVH. I had a minor vibration in the steering wheel I needed to get fixed, and I have noticed it is definitely amplified. They do not squeak though, and the front does feel a little firmer during really hard cornering.
And a question for you suspension gurus, I'm still dissapointed with the handling in the rear of my car. It feels very unstable as if it wants to slide out at any second. As if there's a horrible weight distribution (which there probably is) and the front is weighted down and the rear is not there. What should I do? Currently my rear AGXs are set at 4 (front at 2), and I have an RSB and RSTB (would tightening them help significantly?) Would Stage 1 SFCs help for this?
Thanks,
-Cyrus
Old Dec 8, 2002 | 12:47 PM
trinity000's Avatar
bit of a coincidence but i just literally finished installing my end link bushings and fsb bushing... i have noticed increased steering strength (i.e it is a tighter feel like the car should be). i only took it around the block at this point cause i have yet to get in the shower..
i had no troubles with things springing up on me but i did mine different... take the endlink nuts off on both sides then the bar bushings. installed lower endlinks and set bar onto them slide on bar bushing and brakets and insert bolts a fwe threads.. put top endlinks on and tighten nuts down a bit... tighten down all bar bolts, then endlinks... simple as pie. and considering it is 15 degrees right now i am glad i had a garage (unheated) to protect me from the wind.
Old Dec 9, 2002 | 04:43 AM
95Max's Avatar
Vyrus,
Some quick questions. What springs do you have? What tires and what is the tire pressure? When was the last time you alligned the car? I can't speak to the SFC as I do not have them.
Old Dec 9, 2002 | 12:47 PM
Vyrus's Avatar
Originally posted by 95Max
Vyrus,
I have Sprint spings (w/AGXs), Yokohama Avid H4 215/45-17 tires, 34.5psi all around, and I had an alignment done last weekend.
-Cyrus
Old Dec 9, 2002 | 12:58 PM
costcowholesale's Avatar
Re: FSB Bushings Installed...
Thanks,
-Cyrus
If it feels like the rear is going to go sideways when u're pushing the car hard, u might want to take your rsb out?
Old Dec 9, 2002 | 02:46 PM
ericdwong's Avatar
I still havent put mine in yet cause I'm really lazy. I dont like the sound of having increased NVH. Hmmm. And I'm also putting in the control arm ones.
As for the rear, maybe you should try the motivational engineering strut mounts? Or stop modding and wait to get a real car with a real suspension .
Old Dec 9, 2002 | 07:05 PM
Vyrus's Avatar
They really aren't hard/time-taking to install. With the amount of work you've done to your car Eric, these should be a snap. But you will definitely feel increased NVH. One awesome thing I noticed after driving 20 miles today, is that the steering wheels feels much heavier and harder to turn (as if power-steering is cranked down a level or two). Much more BMW-like. In my opinion the NVH if definitely worth the trade-off for this alone, because let's face it the Maxima has a wayyy too boaty feel especially through the steering wheel.
Oh yeah from what I've heard those are going to be a beyotch. Have fun.
I'm thinking about removing the RSB as costo said, and I am going to buy the motivational rear upper strut mounts when i get the money. They seem like they will do the trick, but you obviously pay the price too.
I wish for once you'd appreciate the Maxima for all it has. But I know that day will never come.
-Cyrus
Old Dec 9, 2002 | 07:16 PM
how bad is NVH? does it sound like an american car @ idle now? or more honda civic like? how $ did shipping cost? u got the front end control arm brushing set for $28 right?
Old Dec 9, 2002 | 07:23 PM
Vyrus's Avatar
It's pretty bad. I had a slight vibration in my steeringwheel, and now it seems huge and the car is going to the dealer tomorrow to get it checked out. Any little rattle or vibration you had is going to get 5x worse. What does it sound like - What do you mean? You can't really see the vibration from outside, it sounds like a normal quiet Maxima. But from inside the steering column and center console shake a lot.
-Cyrus
Old Dec 9, 2002 | 07:26 PM
Vyrus's Avatar
Nope I only have the FSB mid-bar bushings. They were like $7 + $5.12 shipping, damn cheap. I need to get the endlinks though, those are an extra $10. The control-arm bushings are too hard for me ton install and honestly I don't feel them necessary. I don't want too much NVH now.
-Cyrus
Old Dec 9, 2002 | 07:30 PM
-Cyrus
DO I need the endlinks? what if I don't get those? so what part do I order here? http://www.suspension.com/nissancars.htm 7-3111?
just the fsb mid bar bushing will help steering feel? thats all I want
Old Dec 9, 2002 | 07:31 PM
trinity000's Avatar
i put the endlinks and fsb bushing and have noticed the tighter steering wheel as well... but my wheel is rock solid no vibration AT ALL really...
Old Dec 9, 2002 | 07:35 PM
Vyrus's Avatar
No you don't need them, and from what I've heard there will be a very miniscule difference with them so long as you have the mid-bar bushings. The mid-bar bushings will make the most improvement (well maybe the control-arms will, but few want the hassle of installing or NVH of them). All you need is 7-5118 from suspension.com, that's right - $7.
-Cyrus
Old Dec 9, 2002 | 07:37 PM
Vyrus's Avatar
What sprints/struts are you riding on? I'm hoping tomorrow the dealer will find something small that can be adjusted, but I'm fairly sure it's my Sprints w/ AGXs.
-Cyrus
Old Dec 9, 2002 | 07:40 PM
trinity000's Avatar
stock se suspension.. had eibachs but took them off... awaiting my H&R/AGX combo...
then again even if it vibrates it won't bother me... the rest of my fam is into muscle cars so i am used to it but enjoy the feeling of a soild steering wheel in my car
Old Dec 9, 2002 | 07:43 PM
Vyrus's Avatar
See I'm not used to a vibrating steering wheel at all. At low speeds I can't even feel it but on the highway it's real bad. Sometimes I worry I'll lose control. I'm really hoping they can fix it, but if not I still won't be dissapointed. The car handles SO well now I really shouldn't complain.
-Cyrus
Old Dec 9, 2002 | 07:49 PM
trinity000's Avatar
the car does whip around nice.. and with the rsb i like the feeling the back end has... i can whip it around now if i want to more like a rwd car i guess... before it was just like an extra weight on the back.
Old Dec 10, 2002 | 04:44 AM
95Max's Avatar
Vyrus,
The vibration issue...have you had the tires balanced? Have you hit anything. ie large hole, curb... The tire could have a broken belt inside.
Old Dec 10, 2002 | 09:42 AM
ericdwong's Avatar
You're getting all this NVH from ONLY the front sway bar bushings!? Did you change anything else out? Tires, suspesion, rims? Holy cow, I have the front sway bar bushings, the endlinks on order AND the control arm bushings. The control arms have been in my mom's camry for the past 2 weeks. Reason I havent put it in yet is my car is still sitting on jackstands from my blown tranny. Finals week, and its so cold outside I dont feel like working even though i have a kerosene heater in the garage.
Old Dec 10, 2002 | 09:11 PM
Vyrus's Avatar
Vyrus,
Ironic you say that, because last week at Firestone they said that was the problem. Took it to Nissan for a second opinion, and they said I just needed a rotation (which of course didn't work). Now they're saying one of my wheels is bent, but I'm going to take it off and look myself over the weekend. I'm thinking it's a ripped belt, but I haven't hit anything unusually large. And yes the tires were balanced a few weeks back. Thanks for your help bud.
Yeah I am getting a lot of NVH from just the FSB bushings, but like I said above that's not my only problem. It just exaggerated the problem a whole lot. The bushings are VERY easy to put on, they shouldn't even take you an hour. But I see your point, even if you do put them on you can't take the car out for a spin anyways. No biggie.
-Cyrus
Old Dec 10, 2002 | 11:10 PM
thebigsadler's Avatar
bent wheels suck.
ive been thinking about calling ES and seeing about getting a sponsorship thing setup.. I wouldn't mind having ALL my bushing redone, seeing as how air isnt too forgiving on things and I squeak like a motha.
215/45 may have something to do with high end wheel vibration.. or the wheel weights arent balanced.
Old Dec 11, 2002 | 08:40 AM
MAXIN's Avatar
um...please someone quickly define these mnemonics(sp)....
NVH = ??
FSB = front sway bar??
ES = energy suspension??
cant search now....must work....must work..
Old Dec 11, 2002 | 01:19 PM
guido_sst's Avatar
NVH = ??
NVH = Noise, Vibration, Harshness
You are correct on the other two.
Old Dec 11, 2002 | 01:23 PM
SamMan23's Avatar
thanks for defining nvh.
Old Dec 11, 2002 | 02:28 PM
MAXIN's Avatar
thanx.
Starrider
Dec 18, 2015 04:43 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ColdCananda
Sep 20, 2015 10:45 PM
