My air bag light is blinking. How do I stop it.
Old Dec 1, 2002 | 07:49 PM
Midknight MAXX's Avatar
I have a 98 SE. To install an after market head unit the haynes manual recomends that you disable the SRS. Did that and when I was done the light blinks. I already checked the fuse it's fine. Help.
Old Dec 1, 2002 | 07:56 PM
cscm094's Avatar
Hmm not exactly sure, but when it comes to air bags, I wouldn't mess around. Take it to a dealer IMO, probably something to reset or something.
Old Dec 1, 2002 | 08:43 PM
geo1317's Avatar
you probably just triped the computer when you disconected the airbag. There is a way to reset it using the dome light switch on the driver side, but you need to ask someone with a FSM to tell you how to do it. If its a problem the light will just come back on again and then you should take it to the dealer.
Mine is on and i cant afford to take to a dealer so i just put some electrical tape over it(but i dont recommend that get it fixed if you can)
Old Dec 1, 2002 | 10:36 PM
thebigsadler's Avatar
Re: My air bag light is blinking. How do I stop it.
open drivers side door.. put key to "on" position, don't start the car.. press the door sensor (little black number where door contacts car) 5-7 times and then turn the key off.. i think the dome light is supposed to flash a couple times after you do it if done right, but i could be wrong on that.. i've had to do it 3 or 4 times and finally stopped worrying.
mine does it because i put i30t seats in.
Old Dec 2, 2002 | 05:54 AM
genepool's Avatar
If you had used the search button, you would have found this thread which would have taken you to this thread with the answer.
Old Dec 2, 2002 | 08:42 PM
Thanx alot! And about the saerch thing, now I know and knowing is half the battle.
scutmud
Aug 28, 2015 05:04 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
