Vibration when accellerating
Old Dec 2, 2002 | 12:39 AM
iansw's Avatar
Drove to Phoenix and back recently -
During the trip back, I noticed my car was vibrating a little when cruising.
When I accellerate (from any speed), the steering wheel shakes violently, and the vibration feels alot worse.
I have a bad CV Joint on the passenger side causing the "click-click-click" when I turn left.
I have brand new, balanced tires as of 3 days ago, and the problem still exists - tried moving front wheels to the back with no difference.
Is it the CV Joint? Or do these symptoms dictate something else?
Thanks,
IanS
Old Dec 2, 2002 | 12:55 AM
Nismo's Avatar
are your motor/transmission mounts nice and secure?
Old Dec 2, 2002 | 01:15 AM
96_vqmax's Avatar
does it vibrate at idle or only when driving?
Old Dec 2, 2002 | 07:24 AM
iansw's Avatar
Motor mounts have ben checked and look fine.
No vibration whatsoever at idle.
Old Dec 2, 2002 | 07:49 AM
I30tMikeD's Avatar
Are you sure Ben knew what he was doing?
Old Dec 2, 2002 | 09:59 AM
iansw's Avatar
er...."been"
heh.
Seriously, could a CV Joint cause this or am I smoking crack?
Old Dec 3, 2002 | 09:47 PM
96_vqmax's Avatar
Originally posted by iansw
er...."been"
heh.
I don't know,but you can check your cv joint out by jacking both from wheels of the groung,put it in drive and see if it vibrate your tire or not,make sure you pull your parking brake and put something on your rear tire just for caution.Good luck to you and keep us post what's going on.
Old Dec 21, 2002 | 07:47 PM
iansw's Avatar
Dammit! It's still there!
So far I have bought:
4 new tires
2 bent rims fixed
bad CV Joint/axle replaced (done today)
camber bolts (installed today)
alignment (done today)
The vibration is still there! It's not bad until I hit 40, but if I accellerate while over 40mph, the car shakes pretty bad, getting worse and worse the harder I acellerate.
When cruising at any speed, there is no vibration - only when accellerating. - even cruising at 80mph - no vibration.
And here's the strange part - It almost sounds like the vibration is in tune with the sound of my exhaust - or maybe not.
I had a dealership check the engine mounts also, and they said they were fine.
So I've just spent $1100, (tires included) - and it's still happening!
Anyone? Anyone?
Old Dec 21, 2002 | 09:56 PM
|\|issan|\/|ax's Avatar
Re: Dammit! It's still there!
Well, when I had a nasty vibration it was the transmission. The car would shake A LOT!! If yours is an AutoMagic like mine, your transmission needs to be fixed.
Old Dec 21, 2002 | 09:57 PM
ylwgti's Avatar
i would really look into engine mounts, i had exactly the same symptoms, i changed the front mount and saw huge improvement,
but since the dealership checked it I dont know.
may be the other side axle is bad,
i would also go check the ball joints and the tie rods.
good luck
Old Dec 21, 2002 | 10:13 PM
xclo's Avatar
nonono
noo.. you just need a tire realignment! that's cheap to fix
Old Dec 21, 2002 | 10:58 PM
I30tMikeD's Avatar
Re: nonono
[QUOTE]Originally posted by xclo
go back and read the thread again.
Old Dec 22, 2002 | 01:02 AM
96_vqmax's Avatar
4 new tires
2 bent rims fixed
Anyone? Anyone?
so did you try jack the car up(two front wheel of the ground)and put it in drive to see if the vibration is coming from the tires or axle,if not then i think you prolly having a misfire.
Old Dec 22, 2002 | 06:28 AM
iansw's Avatar
Misfire - my A/F maps and Dynos look pretty good. But I'll change my plugs soon anyway - Also, my EGT's are perfect - if I was having a misfire, I think it would feel different.
Automatic Tranny - The shaking isn't that bad, just annoying - I hope to god it's not that.
Other Axle - That's a possibility - I'll look into that, but you think either the guy at the rim shop or the alighnment shop would have noticed.
Motor mount - well, the guys at the dealership were morons, somewhat - they wanted to charge me $650 for an axle (parts only). I'll just have to take a closer look at it when I have time.
Thatnks for the ideas - keep em coming!
IanS
Old Dec 22, 2002 | 07:11 AM
iansw's Avatar
Re: Re: nonono
[QUOTE]Originally posted by I30tMikeD
Bad newbie - BAD!
Old Dec 22, 2002 | 08:18 PM
iansw's Avatar
Anyone else have any input?
Old Dec 22, 2002 | 08:22 PM
cmoe211's Avatar
NO input,but a question...should i go with injen or pr?
Old Dec 22, 2002 | 08:24 PM
iansw's Avatar
I don't know - do you want to cut a hole in your fender or not?
Please send me PM's if you want to chat about it, but don't post here - I need answers to my problem!
Now - anyone have any useful answers or sugesstions?
Old Dec 22, 2002 | 11:28 PM
† ErV †
and then i think i am the only one plagued by weird problems.
same thing here, only mine is not violent and the wheel is rock solid (it should be.. after countless rebalances and allignments) yet it vibrates
engine mounts were changed a month ago, tranny is smooth as silk. i am changing some parts tomorrow and will try to plead with the mechanic to look at the bearings so i wont have to waste another day for them too. if it still vibrates i'll trash it in the shop and keep it there till they fix it. whatever it is. i've had this since i had the car so most likely i inherited whatever the previous owner ditched. oh and mine vibrates motly at 60-100mph when the accelerator is in 1/3 or so. flooring it seems to smoothen it out which might lead to something with the suspension straining under the pressure. go figure.
Old Dec 22, 2002 | 11:35 PM
96_vqmax's Avatar
last time i read someone said that there V1 pully or belt were causing his car vibrate when he apply gas. maybe you can try looking at that,good luck and hope you fix your problem soon.
Old Dec 23, 2002 | 08:22 AM
BlackCat's Avatar
RIP '98 Maxima SE
Hey Ian,
Since you mentioned that you've got 4 new tires I believe its the balancing on the wheels.
When I got my new rims and tires back in April I got the same symptoms when I hit 70km/hr on the hwy. My steering wheel shuddered like crazy. When I took my car back to the tire shop they rebalanced the fronts and it was fine after that. I'd check that out.
Old Dec 23, 2002 | 08:36 AM
iansw's Avatar
Originally posted by BlackCat
Hey Ian,
Thanks for the suggestion, but it's only when I accellerate - when travelling at 70mph (or any speed) and not accellerating, then it's smooth as glass.
So the balance idea seems off - I've also had them rebalanced 3 times since I got the new rubber on with no improvement.
I do know part of it is that my camber was off and now my tires are lightly worn on the inside. Now that I have the camber fixed, it's causing vibrations.
But this vibration is totally seperate from that.
I'm thinking now it's one of 3 things:
1) Motor Mount
2) SC
3) Tranny <----------
How are you liking that 3.33" Pulley?
IanS
Old Dec 23, 2002 | 09:26 AM
SonicDust187's Avatar
You said that it almost vibrates to the tune of your exhaust, why not check the exhaust, maybe it is rubbing or vibrating under acceleration. Maybe one of the hangers of flanges broke. My $0.02.
Old Dec 23, 2002 | 10:10 AM
iansw's Avatar
It's definately coming from the engine bay/front wheels, not under the car.
It shakes the steering wheel badly - i doubt an exhaust hangar could do that.
The more I think about it, the more I think it's my tranny about to go.
IanS
Old Dec 23, 2002 | 10:14 AM
Jeff92se's Avatar
I'm needing a caw
I've never heard of that problem = a bad tranny though. But you could be the first. Level okay and the fluid looks okay? You "might" want to take a sample and send it to Blackstone labs and see what they have to say about it.
IanS
Old Dec 23, 2002 | 10:15 AM
iansw's Avatar
Hey Jeff, you willing sometime later this week to take a quick ride with me (with you driving, so you can feel it more)?
Maybe you could diagnose it....
IanS
Old Dec 23, 2002 | 10:20 AM
Jeff92se's Avatar
I'm needing a caw
Sure. Pm me your numbers and we can try to arrage something. I'm pretty busy until after x-mass. Maybe this Fri after I get done coaching b-ball. It's at Meany middle school(near 23rd and Madison). Maybe we can meet real quick or have a short meet w/ Matt?
IanS
Old Dec 23, 2002 | 11:37 AM
xclo's Avatar
lol yea i'm newb at this sorry.. but my wobbling and shaking DID stop when i got my tires aligned
Old Dec 24, 2002 | 12:15 AM
96_vqmax's Avatar
he said it only happen when he accellerating,if the tire is out of balance then it only vibrate at certain speed doesn't matter accellerating or not.
Old Dec 24, 2002 | 02:48 AM
Aznwhitemax's Avatar
hmmm my steering wheel and my dashboard(i think) starts vibrating after i hit 70 could it b the saem problem?
Old Dec 24, 2002 | 07:34 AM
iansw's Avatar
No - mine doesn't vibrate at 70, or 120 for that matter, if I'm not accelerating.
Why is it you people have a problem grasping this concept?
Damned newbies.
Old Dec 24, 2002 | 09:26 PM
iansw's Avatar
Problem fixed!
Solution: Tranny Fluid was 1/2 Quart LOW!!!!!
Took her for a test drive across I-90 tonight at blazing accelleration. No shake whatsoever!
Old Dec 25, 2002 | 12:21 AM
iregula's Avatar
axle?>
Old Dec 25, 2002 | 12:49 AM
iansw's Avatar
Originally posted by iregula
axle?>
I replaced the axle last week, but that only solved the clicking when turning, not the vibration.
Old Dec 25, 2002 | 12:56 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
i got this prob too after i put in my motor mounts, then we looked at the passenger side axle and the 3 bolts for the intermediate shaft was loose. tightened those and MOST of the vibration went away.
Old Dec 25, 2002 | 01:08 AM
iansw's Avatar
We torqued the axle to spec when installing it....
Anyway, like I said, it's fixed already.
Old Dec 25, 2002 | 02:30 AM
maxNYC's Avatar
Problem fixed!
Good on you
I hope you changed the tranny fluid completely because all the grinding experienced probably left metal shards and deposits in the fluid. Im glad you solved it.
Happy holidays
Old Dec 25, 2002 | 10:11 AM
iansw's Avatar
Originally posted by maxNYC
Good on you
Happy holidays
I've got a full flush scheduled for this weekend.
Old Dec 25, 2002 | 09:52 PM
96_vqmax's Avatar
Problem fixed!
glad you solve your problem,peace.
Old Dec 26, 2002 | 12:16 PM
iansw's Avatar
Went for another drive this morning, and it's back!
Damn.
Although I did notice it only happens when boosting - the more I boost, the worse it is - so I expect it's gone something to do with the SC. I checked it out and the belts and pulleys look great, and the thing is mounted to the engine so tight that when I pull my hardest on it, it doesn't budge.
96_vqmax - Can you link me to that thread about someone having the vibration with the SC? I can't find it.
Thanks,
IanS
