Need help with Passenger Side Driveaxle
Old Dec 2, 2002 | 11:39 AM
ShinseiRyu's Avatar
A friend and I are working on replacing the Passenger and Driver side Driveaxles and have run into a problem with the passenger side. We cant get the passenger side out at all. Any help appreciated. Pics of the problem below.
Old Dec 2, 2002 | 11:57 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
youll juss have to pull it out hard. SOmetimes you can spray some WD-40 there to loosen it up. or spin it to loosen it up. knock it out with center punch and hammer or pry it. whatever works.
Old Dec 2, 2002 | 02:33 PM
iwannabmw's Avatar
The only way to get this is with a hammer and chisel or screwdriver. Just keep spraying it with a rust penetrant and whack the hell out of it with a hammer. Be patient with it, it takes time.
Old Dec 2, 2002 | 02:41 PM
ladeesman's Avatar
Looks like that third bolt is still on back there bud.....not sure but thats what i see.
Old Dec 2, 2002 | 02:50 PM
ericdwong's Avatar
Yea make sure you take off all 3 bolts that are 12 mm. Its probbly seized, so this is what I did. put 3 bolts in and back them out a tiny bit. Then- use a hammer being careful not to *****-head the bolt, hit the bolts so that it will push the axle out of the bracket. There is no snap ring, so it will side right out. After that antiseize the bracket.
Old Dec 3, 2002 | 08:20 AM
genepool's Avatar
That stupid axles was a b!tch to replace I thought it was going to take no more than 90 minutes but took me about 4 hours..... Anyway, I wedged a big flat head between the 2 pieces and separated it little by little.....and chipped a piece of the bracket bearing in the process Now, no more noises from that axle
The Wizard
24
Oct 1, 2015 08:47 PM
lkiller123
Sep 21, 2015 03:00 AM
Bonka
Sep 14, 2015 11:18 PM
Colossus
Sep 9, 2015 05:46 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
