No more heat??!!
Old Dec 3, 2002 | 06:37 PM
Clake's Avatar
No more heat??!!
I have a 95 Maxima GLE and this year I cannot get any heat (hot air). The engine gauge will now barely touch "C" and only goes higher if I sit in traffic for a bit. Once I start moving, the needle goes right back to "C". Never had this problem in (winters) past.
Can anyone help?
Thanks in advance!
Old Dec 4, 2002 | 06:27 AM
MIXXMAX's Avatar
Re: No more heat??!!
Can anyone help?
Thanks in advance!
You might want to check a number of things. Start with your thermostat. Also, you might want to check your coolant level, and maybe your coolant temp. sensor.
Old Dec 4, 2002 | 06:52 AM
Rit's Avatar
Rit
Sounds like your thermostat is stuck in the
open position. You are over-cooling your engine coolant. Also, your engine is probably always running "rich" because it thinks that you have just started up a cold engine. Try replacing the thermostat - cheap fix, and go from there.
Old Dec 4, 2002 | 07:05 AM
DeRaNgEd's Avatar
Re: Re: No more heat??!!
First thing I would check.
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
captchaos
Mar 15, 2016 12:18 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
