Hard start in mornings -- help?
I just changed the fuel filter and spark plugs in my 95 GLE and now am having trouble starting the car. it takes about 3-4 tries to get it started -- that NEVER happened before. The work was all done by me and has been about a week so far. I put in Bosch Platinum plugs, and a regular fuel filter. Any help is appreciated.
Originally posted by njmaxseltd
Get rid of the Bosch plugs.
Clean your throttle body.
Check you ECU for any codes.
The 1st winter I had with Bosch plugs, I had hard starts. The plugs looked fouled when I pulled them. Subsequent hard starts were resolved with the TB clean...
NGK
I've always had good experiences with NGK in all my Nissans and Madzas that I've owned.
Originally posted by Daniel 91 SE
what plugs should I switch to, and could that really be the problem?
Re: Re: NGK
Is there a reason Maximas and Bosch plugs don't mix?
If you want to get a "good spark" Spark plug, stick with the NGKs. They are used by the factory for a reason; they are just better for our type of engine over the domestic engines. If you want to save some money but get a very good plug, get the NGK coppers. Granted they do not last as long as the Platinums, they do in fact give a better spark.
Originally posted by Mishmosh
You can get throttle body / intake system cleaner at almost any auto parts store.
I thought I read somewhere that throttle bodys were coated with something from the factory. and that you should not clean them except with certain types of cleaners. The coating was to prevent buildup of gunk, and that if you did clean them with the wrong product you would need to do it repeatedly after that because the coating would be cleaned away?!?!
$10 PER PLUG?? Is this a normal price PER plug??
I am a dealer so this is cost not list price, but it sounds high.
anu
is there a page on the web with instructions for how to clean the TB? Mine has trouble starting everytime since the weather has gotten cold. it makes a very nasty metal-grinding sound. i already changed the starter and the sound still exists and it is hard to get the car started.
97_GXE
Sep 15, 2015 06:47 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
