Rattle drivng me crazy
Old Dec 8, 2002 | 08:49 PM
NATE98GLE's Avatar
There is this rattle driving me crazy coming from under my car in the area near the y-pipe. It only does it when the car is in drive. When it is in park it stops. Would anyone have an idea what it is?
Old Dec 8, 2002 | 09:39 PM
ch13f's Avatar
Same exact thing happened to me when I got my Y installed, im auto and it only happens when im in "D". It seems like the y pipe is touching something that it shouldn't be. Im probably going to just wait until I get a cat-back to do anything about, I doubt it'll be difficult to fix, maybe some header wrap to insulate the areas that are making contact
Old Dec 8, 2002 | 09:55 PM
SlavDaddy's Avatar
Don't trust me, I'm sneaky
Could it be the heat shield?
I know I had a rattle a while back, and it turns out there was a rock stuck in between my cat and the heat shield job. Could that be it?
Old Dec 8, 2002 | 09:58 PM
nadir_s's Avatar
vicodin ... gift of life
i have a rattling shifter now... i dunno what could be the problem and it's starting to **** the crap outta me
Old Dec 8, 2002 | 10:24 PM
oCtoG3's Avatar
if you got a rattle under idle I can't think of it being anything other than your heatshielding. Leave your car running and get underneath, heatshielding is very easy to bend to eliminate rattling, just remember not to touch the exhaust piping. and don't drink excessive amounts of alcohol before doing it either. or smoke crack
Old Dec 9, 2002 | 06:46 AM
NATE98GLE's Avatar
thanks, ill check it out
Old Dec 10, 2002 | 06:02 PM
Street Reeper's Avatar
Handsome
I don't know if this is the same as your problem but this was mine. I installed the WS Y-pipe and everything worked great. The only problem was when I put the car under heavy load (downshift, floor it) a buzzing/rattling would happen occur right underneath the shifter for a split second (auto)
I put the car up on a lift and had someone power brake it and give it some gas (to apply load, in neutral the rattling would not occur) What I saw was the Y-pipe shifting around like it was a bear caught in a trap (thats why a heavy flex section is a must.)
I bent a few things out of the way and now it works great, and no noise.
Instead of doing somthing dangerous like jacking your car up and power braking it, just look under your car where the flex section is, now imgaine that your Y-pipe needs about 1.5 - 2 inches of clearence around it. Bend anything that conflicts with this out of the way.
I hope this helps.
Old Dec 10, 2002 | 06:06 PM
meccanoble's Avatar
Sports Button FTW
Re: Rattle drivng me crazy
yea, i was gonna say heat shield too. Mine made a nasty klink klink sound when turning (on my old max) and found out y-pipe was hitting heat shield, just like pop it up more or something...u can take it out but u may let it a lot of heat inside the car which might not be very comfortable...
Old Dec 12, 2002 | 03:42 PM
NATE98GLE's Avatar
Well, I found out that the rattling is my failed Carsound Cat. I am hopin that I can get ir replaced free of cost. I still have my warranty certificate. Does anyone think I will have a problem getting a new one? Is Warpspeed an easy company to deal with for returns or replacements?
user 11122324
42
Jul 18, 2022 03:35 PM
Garrettz459
Sep 28, 2015 02:50 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
