Error Code 0102 (Mass Air Flow Sensor) *Help*
Old Dec 9, 2002 | 08:10 AM
IncandescentSE's Avatar
***I posted this in the Gen. Maxima Forum but I haven't gotten any responses. Hopefully, I can get some here.***
Last Saturday, as I was pulling out of the driveway, the car sputtered a little. I looked at my dash and sure enough the SES light came on. I pulled out the code and it turned out to be the MAF sensor. I reset the ECU and it hasn't come up since.
My question is: Is there something really wrong with the sensor or could it have just been a false alarm. I've heard that if the MAF sensor is realy f***ed up, the RPM's usually won't go past 2,500 or so. Should I stop worrying about it or should I start searching for another MAF?
99 SE Maxima
Old Dec 9, 2002 | 10:50 AM
mzmtg's Avatar
Minister of Silly Walks
Reset the ECU and see if it comes back. If it does, you probably need a new MAF.
Old Dec 9, 2002 | 02:59 PM
I reset the ECU that same day. I have noticed a pretty big drop off in gas mileage though. Could that have anything to do with the MAF???
Old Dec 9, 2002 | 03:30 PM
Jamsan's Avatar
if you have any friends, try swapping MAF's and take a test drive...it most likely is your MAF going bad....time to hit up some junk yards, because MAF's are a pretty penny
Old Dec 9, 2002 | 03:33 PM
SuDZ's Avatar
Few hundred buck easy.
SuDZ
Old Dec 24, 2002 | 08:34 PM
Pseudopods's Avatar
I too got a 0102 code today. Car has been running poorly for some time now, hesitating, did some bucking last week (replaced the fuel filter after that). The car feels starved at 4000 RPMs, which it won't go to unless I hold it in gear (auto) and shift manually.
No other codes popped up but 0102.
Is the MAF difficult to replace?
-Seth
Old Dec 24, 2002 | 08:38 PM
Jamsan's Avatar
MAF is def dead...you can try cleaning out with some K+N cleaner if you have some, no harm in trying....other than that, just replace it..its not hard it all, just unbolt your stock air box/intake, and then the midpipe area, disconnect the sensor, and then put the new one in, plug in the sensor, and replace the intake and midpipe.
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
homeyclaus
Sep 3, 2015 06:15 PM
bc992164
Aug 26, 2015 12:19 PM
doobadoo
Aug 15, 2015 06:43 PM
