royal purple
Old Dec 9, 2002 | 08:30 PM
henock
royal purple
I saw a camaro gain about 10-14hp from royal purple oil, tranny fluid, and differential fluid on TV on one of those tuning shows. WOuld this be accurate and would it actually help performance on maxes?
Old Dec 10, 2002 | 12:19 AM
thnikkamax's Avatar
Ludicrous Speed
Re: royal purple
Hmmm... he probably didn't gain HP. Just got some of the HP restored from the crank to wheels process, but in a higher HP car where 15HP is a big diff between crank HP and wheel HP. I think.
Old Dec 10, 2002 | 07:11 AM
Lime's Avatar
which royal purple oil?
Oil doen't give horsepower in and of itself anyway, that's a crazy claim to make.
I am running the RP 5w30 oil, and it seems okay, but perhaps not as long-lasting as AMSOIL.
Old Dec 10, 2002 | 07:58 AM
jbreit's Avatar
synthetic oils do have a lower friction coefficient, and it will translate to a little power at the ground...but that claim sounds pretty high....i would believe 6-8 on a 300Hp camaro.
For a few years I did gear box design on heavy trucks. We would do life testing with petroleum based and synthetic oils. Synthetic would run 8-10% cooler (we are talking 600 Hp and 20000 Ft-lb gear boxes) and generated less wear....life was not impacted in our tests as gear teeth would fail first...We did extend oil change intervals with customers that used synthetic because oil contamination and breakdown were decreased. Our testing did not measure HP "losses"...which in this case is mostly a factor of gear design.
When I was still motorcycle racing we dyno'd oils against each other and AMSoil, Redline, Bel-Ray had gains of approx 2% over say Kendal or Castrol GTX...but in a motorcycle, the oil is shared by the gear box as well. It was noticable how much longer a synthetic would hold up than "conventional" oil given that gear box action and clutch feel were both impacted.
engine oil is a different set of criteria than gear boxes...you have contamination from the combustion process (that gets worse with age/ring wear) as the main reason to change your oil...especially if you just make short trips where the engine doesn't get up to temp for a long period to burn off those contaminants....you'll have to make your own decision about extended drain intervals on your engine.
when I was racing i would spend the money on synthetic....it was cheaper than rebuilds. but i don't in my daily drivers (not the engine anyway, transmission and axles yes). If I ever buy a new car, I might get on the amsoil program from the start...we'll see.
halfpol
Oct 17, 2022 12:16 PM
Wareagle92
Sep 3, 2015 07:18 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
halfpol
Aug 5, 2015 08:24 PM
