My auto made me so proud yesterday
Old Dec 10, 2002 | 07:53 AM
Conrad283's Avatar
I need a truck
There i was comtemplating going 110 mph .... so i gun it so i'm already in 2nd gear and i get up to 6000 rpm and i hit the O/D button off ... and i shifted into 4th gear and it kept pulling and pulling ... and it made me so proud
Old Dec 10, 2002 | 07:55 AM
mzmtg's Avatar
Minister of Silly Walks
Go ahead and take 3rd gear all the way to redline
Old Dec 10, 2002 | 08:05 AM
Conrad283's Avatar
I need a truck
i never grow old of seeing that pic, good job
Old Dec 10, 2002 | 08:15 AM
Jamsan's Avatar
I've taken third to redline, maybe a little less, and it was damn fun...it'd be hella funner with a MEVI, but beggers can't be choosers...anyways, I don't plan on doing any 100mph+ runs until new tires come in
Old Dec 10, 2002 | 08:18 AM
Joeycurl's Avatar
So how did you do that? You left it drive and then turned off the O/D?
Old Dec 10, 2002 | 08:21 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
No MEVI. I can't make it to redline
Old Dec 10, 2002 | 08:26 AM
mzmtg's Avatar
Um...yes.
Old Dec 10, 2002 | 04:48 PM
Conrad283's Avatar
I need a truck
i was already in motion so i was in second gear ... then when i got to 6000RPM, i turned O/D off and then it skipped over 3rd gear and into 4th
Old Dec 10, 2002 | 04:51 PM
naijai's Avatar
i almost redlined while downshifting once got all the way to 6ooorpm
Old Dec 10, 2002 | 04:53 PM
SuDZ's Avatar
Always a fun pic.
SuDZ
Old Dec 10, 2002 | 05:11 PM
mzmtg's Avatar
Originally posted by slammed95
Try fourth gear at nearly 6000 rpm. Way past the last number on the speedo.
Your Max wont go that fast...
Old Dec 10, 2002 | 05:13 PM
Conrad283's Avatar
I need a truck
not unless they pave a road down mt. everest
Old Dec 10, 2002 | 06:30 PM
Romeo's Avatar
...or on a dyno
Old Dec 10, 2002 | 06:47 PM
gtr_rider's Avatar
192.168.1.1
take it on a dyno and it 170
Old Dec 10, 2002 | 11:48 PM
johnvt1111's Avatar
with od off you can't go into fourth, i think ur confused.......having the od switch off keeps you in 3rd
Old Dec 11, 2002 | 12:40 AM
meccanoble's Avatar
Sports Button FTW
what is this, an autotragic reunion ???
Old Dec 11, 2002 | 03:23 AM
Silviagirl79's Avatar
damage
Wont that do any damage to your car?
And where were u when u were doing this?
Old Dec 11, 2002 | 03:37 AM
dcmaxclub's Avatar
Actually it will. Motor Trend had the 4th Gen max up to 144mph. The 95 model I believe. Check for one of the old books, It was called the 140mph shootout. The Taurus SHO also made the cut while surprisingly the mustang GT did not. The aerodynamics were too poor, but when they put cardboard flaps over the headlights on the GT they were able to get over 140 -- barely.
I'd tell you the issue number if I could find the damn thing.
Pretty sure it was an SE though, but with a mod or few I'm sure the auto could make it.
Old Dec 11, 2002 | 04:25 AM
mrmaxima97's Avatar
Old Dec 11, 2002 | 05:08 AM
mitch33x's Avatar
the max they tested was a 5speed
Old Dec 11, 2002 | 05:18 AM
mzmtg's Avatar
6000 rpm in an automagic Maxima is about 170mph. My max will go 140mph too, but that's only about 4800 rpm.
Old Dec 11, 2002 | 05:20 AM
Sprint's Avatar
Old Dec 11, 2002 | 06:07 AM
Conrad283's Avatar
I need a truck
my tach speaks for itself ....
Old Dec 11, 2002 | 11:47 AM
mzmtg's Avatar
And explain why it can't reach that speed?
I know for sure that I saw my speedo needle at least 1/2 inch to the left of the "140".
I'm sure you can put the needle past 140mph. But, there is no way you are hitting 6000rpm in 4th gear...if you are automatic. As I posted above, that's 170mph.
Old Dec 11, 2002 | 01:06 PM
96SE5Spd's Avatar
Drag
Old Dec 11, 2002 | 01:30 PM
96SE5Spd's Avatar
I'm well aware of the effects of drag. At 5500 rpm, with my 235/45/17 tires, that would put me around 155 mph. Is it really that hard to believe?
I may just have to take some pics of the speedo and tach at that speed to show that an auto NA max can go 150+. That's if someone else is willing to be in the car.
I wouldn't know if an auto could go that fast or not (stock) I have a manual, I was answering your question since no one else did.
Old Dec 11, 2002 | 01:36 PM
deezo's Avatar
As long as I've been here, I haven't seen it done. To do 150 in a stock auto, you're going to need a hell of a long road with no police for 20 miles.
Old Dec 11, 2002 | 01:42 PM
96SE5Spd's Avatar
There is a place in Alabama on I65 that is nearly impossible to be chased by cops unless they are behind you, I've had my car to 140 there a couple of times I don't know if it is possible for a auto to go 150+ but this would be the place to try. (BTW for those of you who live in Alabama its the Dolly Pardon Bridge).
Old Dec 11, 2002 | 02:02 PM
mzmtg's Avatar
I live in AL, let's meet up. I'll take the pic as you drive 150 in your Auto Maxima.
Old Dec 11, 2002 | 02:08 PM
Conrad283's Avatar
I need a truck
i would definately be scared ****less if i were in the car with someone (not driving) going 150 ...
why can't there be any roads like that up north?
Old Dec 11, 2002 | 03:20 PM
mzmtg's Avatar
I don't think most people with stock autos would try it. My car isn't stock though. Also I no longer have a speed limiter because of my G-Force ECU.
I no longer have a speed limiter becuase I know which wire to cut.
Old Dec 11, 2002 | 03:36 PM
Joeycurl's Avatar
which one would that be?
Old Dec 11, 2002 | 03:38 PM
mzmtg's Avatar
It would be detailed in the FAQ
Old Dec 11, 2002 | 06:06 PM
Romeo's Avatar
But unlike your ghetto mod, I gained power with it too.
yes but your's also cost ~$450-$500. i imagine mzmtg spent $1.50 at radio shack on a switch
Old Dec 13, 2002 | 04:10 AM
dcmaxclub's Avatar
Thanks, I didn't have the issue handy.
So, if a stock 5spd tops out at 144 with wind drag, then I think a modified auto should be able to get 140. Actually, a stock auto *should* be able to get it as well, since top speed is limited by drag more than HP. It just may take a lot of road like someone else mentioned.
I think even if you guys do get a picture with the speedo pegged way past 140, it won't mean that you are going 150 because of speedo error at high speed. Maybe if you can get a pic with the speedo and with GPS registering the speed it would be more credible.
I don't think it's worth the risk of trying it on a public road though, unless someone in AZ or somewhere can get out in the desert and do it ;-)
Old Dec 13, 2002 | 05:39 AM
Nismo87SE's Avatar
Cartest shows a stock 4th gen 5spd topping out around 137-138mph @ 5900rpm in 5th gear. A stock automagic would pull 133-134mph @ 4600rpm in 4th gear. Also for any 4th gen maxima to go over 150mph it would need at least 200whp, to overcome the aero/tire drag.
Old Dec 13, 2002 | 06:46 AM
Stephen Max's Avatar
If the stock 4th gen 5 speed was using all of its rated 190 hp (at the crank) to get to 138 mph, then it would require 244 crank hp to get to 150 mph.
190 x (150/138)^3 = 244
Old Dec 13, 2002 | 07:06 AM
mzmtg's Avatar
Since we know the speedo is unreliable at best when travelling at extra-legal speeds, we should use the tach.
For my car 60mph (well within the speedo's useable range) equals 2100rpm.
2100rpm / 60mph = 35 rpm/mph
I can safely estimate my top speed by using that formula: 4800rpm / 35 = 137mph
Old Dec 13, 2002 | 07:34 AM
Viscous's Avatar
I've mashed my stock auto to the floor for about 7 minutes straight five years ago when it was pretty new. It hit 137, only after a gruelingly long time. It stayed at 137 for about 2 minutes with no more gains whatsoever. There's no way in hell that a stock auto with no mods whatsoever could break much over 140 unless hell froze over. 150 would mean your gauges are just plain broken or inaccurate.
Old Dec 13, 2002 | 07:39 AM
Conrad283's Avatar
I need a truck
were you going uphill? some people may drive a little different than you, so it's possible
