Best low end torque mod
Does a Y pipe give you any increased low end torque or is it all in the upper RPM range. If it's all upper RPM what kind of mods give you increased low end torque. I want both but would rather start with some low end torque, I have a decent intake, seems it added upper RPM power...........and I REALLY want some wheel spinning torque off the line......whats the best bet?
2Maximas
2Maximas
Re: Best low end torque mod
2Maximas
2Maximas
Re: Re: Re: Best low end torque mod
You could also rev to redline and drop the clutch, may want to hold on if you have **** tires cause it may get squirely. Dunno have only had mine a week.
not responsible for damage cause by listening to my dumb*ss, this was meant as a joke
Re: Re: Re: Re: Re: Best low end torque mod
Originally posted by SuDZ
It would not suprise me if some people went for it
SuDZ
SuDZ
What is the best mod for torque for a NA Maxima? I really don't want to burn the tires down, just want some lower end power. I'm putting on a Y pipe (Christmas gift) and as stated before have an intake with a K&N cone filter. Where do you see the improvements from a Y pipe? Across the whole rpm band or just at higher revs?Off the line my Max (all Maximas IMHO that are mostly stock) is a slug. Having an auto doesn’t help any either, I realize that. But there has got to be something that will help develop some low end torque. Any REAL suggestions would be GREATLY appreciated.
TIA
2Maximas
Ok you want real answers, I have never built up a maxima engine but I have done tons of work on DSMs. Intake and exhaust are cheap and may give some gains you could also try lighter pulleys and flywheel to help get going a little faster. If you want a really noticeable difference bore and stroke your engine. You might want to try a stall converter. However, that auto is always gonna limit you off the line and not all stock maximas are slugs, I have limited experience so far but my 5spd jumps off the line, peeling out in first and second is easy though so I have to watch my heavy foot till I make some improvements.
A Y-pipe adds to your power band after 3500 RPM's. You may loose a couple HP before that. Why are you so concerned about low end torque. Yes, it's nice to have, but if you are really pushing your car through the gears you will only be below 3500 RPM's in first gear for a split second. After that you will only be in the mid and high end range of your power band.
You can see a dyno of a Y-pipe here.
http://www.motorvate.ca/auto/maxima/...-pipe_dyno.htm
Originally posted by 95emeraldgxe
high stall torque convertor makes you lose some off your low end power....
The Place Racing CAI will give you the best low-end performance.
But you have a VQ, heck, even a 4th Gen VQ (gobs of low-end for a V6), so I really don't know how much more you want and if a PR CAI would do it for you. The 4th Gen Maxima is **MUCH** more enjoyable with a 5spd. No complaints about low-end here, as I can already light up the front tires from a slow roll in 1st if I stomp on it just right.
The S/C doesn't really produce any boost until you're beyond 3000rpm, so that wouldn't really help for low-end.
Nitrous would, though
But spraying right off the line is rather rough on the engine...
Low end torque comes from building the engine, such as: pistons, cams, flywheel, clutch, etc.(maybe an UD pulley also)
Y-pipe, cat-back exhaust, intake all add their major increase at about 3500-5500 rpms cause thats when good air flow is essential.
superchargers and turbos and NOS are an all around torque enhancer. from low end to high end.
Did you replace your intake resonator with a mid-pipe, because if you just replaced your filter box and kept the resonator then you lost tons of low end torque. I did this and it was 6 months of no low end torque before i found out that the stupid resonator was the problem. I got 17' rims and my car peels like a ****, but that was after the mid pipe. You can buy from from that frakin company or you can make one with home depot stuff. I'm broke so i went to hope depot and gheto rigged it
Originally posted by JeffesonM
get a 5spd.
get a 5spd.
do a 5spd conversion and you won't have any trouble burning out right through first. and no, you don't have to drop the clutch at redline. launch at 2G's, get off the clutch so it doesn't get worn down and floor it.
* this will occur with stock goodyear eagle rsa's or another set of tires just as crappy
Ok, I'll chime in here since this was and is still my ongoing quest.
My first two mods were the PR CAI and the UDP. That coupled with a 5sp provided 0-60 times of 6.4x sec. Back then I was running a heavy 48lb 17" wheel/tire combo. Lighten that up to like 35lbs at each corner and I bet 6.1s/6-2s would be possible for only a couple hundred $$ if you could launch it. (I still suck at launching myself)
Opening up the exhaust will negate low end. Same with the y-pipe and a hybrid or cone air filter.
I'm already over 200fwtq now and aiming for 210-225 this year.
Originally posted by hacim105
What is the intake resonator? Never heard of it. What did you do when you put on your intake. I have a pop charger but I might put that little pipe instead of the box. Where is that resonator?
I have the midpipe and it does not(at least for me, and most other) return much low end torque lost with the pop charger. It just looks better and sound a little differnent. I would believe that the previous post about the great low end torque it provides is a little questionable. It's probably in his head.
Contrary to most peoples beliefs, the y-pipe DOES add low end as well as top end. If you look at the dyno of a y-pipe equiped car it makes more power through the ENTIRE REV RANGE...not just above 3500.
I personally think my VQ has PLENTY of low end grunt. I have the normal N/A bolt-ons and I can start in first gear at 1000rpms....with the clutch FULLY engaged and just hammer the throttle and my car will rip the tires loose straight to redline...that's PLENTY of low end for me. Any more would be completely unuseable.
Originally posted by I30tMikeD
The resonator is that black square box after the MAF and before the TB. It has a hose connected to it.
2Maximas
Here are some pics of what I have, http://www.almand.net/html/photos.html Ordering the Y pipe from budget today. From what I understand the B pipe is not that important (as far as making power goes...like 1 to 2 HP?) So I think I'm going to keep the factory exhaust except for the Y pipe, and then maybe add an UDP. Some one had a source for something less expensive than Unorthodox Racing....any one know who that is? Oh and the leather is from the group deal with leatherseats.com. It turned out really good IMHO!
2Maximas
2Maximas
2Maximas
Just ordered the Y from budget.....I CAN'T WAIT to get it! Everybody here says it's such a good upgrade for our cars. Now I'm off to get some NGK coppers, and try to get back some of the lost HP. I bought the car used and I bet it's NEVER had a plug change and it's got 105K on the clock.....guess I should get a fuel filter and oil change stuff too.....Nissan filters, as far as oil, I don't know the history of the car and I'm wondering should I use synthetic oil? If the oil was not changed on a regular basis, will the synthetic loosen up gunk and clog my oil pan pickup screen? Whats everyones thoughts on that? I've seen pros and cons on it.....
2Maximas
2Maximas
2Maximas
2Maximas
y-pipe to add that much low end power when it is part of the exhaust and wouldn't need great airflow until higher rpm's,because that's when the air is really flowing. Just like a turbo has turbo lag because airflow has to spool up. That's why you feel a jump in power when you hit about 2650 rpms because that's when it really kicks in.
If you engage at 1000 rpms and are burning your tires then you have other modifications. Most peoples car idle from from about 600-800 RPMS. ripping your tires at 1000 rpms would mean A LOT of torque.
Post this dyno your talking about. It is quite difficult for a
Originally posted by Dev
exactly.
exactly.
Originally posted by 96SE5Spd
Not so, my car stock would burn the tires rolling at 5mph (thats idleing) so you don't have to have alot of mods to make this happen, First gear is really short in the Manuals.
Well I'll go test it today and tell you what I come up with. I have a 5 spd with a y-pipe, intake, and custom catback. And I've never burned out at 1000 rpms. But i'll try it and see if I can. I know that 1st gear is short and that's why you go through it so fast. But i'll gate back to you and tell you what happens.
A turbo takes time to spool up, and so does a SC.
They don't help low end at all - seing as the stock Stillen SC, for instance, doesn't kick in until 4500RPM. Even with a 2.87" Pulley, 2800 or so RPM.
Same with a Turbo.
IanS
Same with a Turbo.
IanS
Same with a Turbo.
IanS
Same with a Turbo.
IanS
Remember this car was bought with over 100K (or maybe slightly less I don't remember)on the clock, and I have no idea of the maint. history. Should have the Y pipe by Friday or Monday, and I'm going to install it myself. Budget told me it comes with all the hardware. I have a floor jack and jackstands. Also have a compressor and air tools, so it should be fairly easy..........right? Did anybody have an address for some company besides Unorthodox for a UDP seems someone around here said that there was another brand for less bux.....
2Maximas
Well I can understand if he has an ACT clutch but this guy said stock.
The clutch isnt gonna make any difference in wheel spin if you launch at 1000rpm. An ACT will pop just as quickly as the stock if you allow it to.
