Differential Bearings on I30 LSD and Canadian Maxima LSD
Ok, as we all know, the differential bearings on our 5-speed transmissions are not properly shimmed. Well, in the past 2 weeks, I have gone through three Right side CV axle seals and the axle itself has about 2-4 MM of free-play. Resulting in this, I have bad differential bearings. I have been researching into getting a LSD transmission for some time now and I have a few questions about them. Are the differential bearings on the LSD transmissions (either I30 LSD or Canadian Maxima LSD) properly shimmed? Or, even if I get a LSD tranny, will the differential bearings fail on me? Thanks guys.....
Re: Differential Bearings on I30 LSD and Canadian Maxima LSD
i got a brand new VLSD tranny from Nissan. 1 month after the waranty expired it went out on me. Started clunking reallly bad in turns like a bad CV joint, then it clunked all the time. driver side axle seal started to leak so i replaced the whole tranny with another.
ZTY Max, a friend of mine, has the same symtoms as me, and i think his tranny is on the way out, I first noticed when i was fixing his shift linkage and i saw fluid leaking out the driver axle. he has slight clunking noise also. His is a 97 with Nissan VLSD tranny, supercharged.
I am in canada . I have a 5 speed maxima se with LSD and my trans is on my workbench in the basement as we speak. My differential bearings went and I just replaced them. I don't think it matters what type of diff. you have. I think it is an assembly problems or just the tranny sucks. I actually wonder if there are more bearing failures with LSD differntials?
ef9
Aug 14, 2015 03:03 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
....Looks like I just may get a LSD tranny and rebuild it myself.....
