Sam feels like venting
Old Dec 13, 2002 | 05:25 AM
NotNew!!NewSN!!'s Avatar
My maxima blows.
bad front bank 02 sensor
knock sensor
closed loop control (whatever that is)
starter is almost gone
strut bearings and bushings are done
bose speakers are just vibrating the doors now
ACT clutch engages very bad, sometimes at bottom, sometimes at top
front agx's feel like their almost blown (stupid detroit)
and its cheating on me....
sorry, im poor as hell, im working full time at an internship in detroit right now (gm's supplier of race, pace, concept cars) and take the low pay for the good experience. Rent, groceries, gas, car payments, cell phone, haircuts. I'm only 18. Hopefully ill get this all fixed at our garage in pittsburgh, but im just sick of dealin with this crap every morning on my way to work. I'm sure it will get locked, i just needed to vent.
Old Dec 13, 2002 | 08:02 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Re: Sam feels like venting
Originally posted by NotNew!!NewSN!!
My maxima blows.
knock sensor
where in pgh, i know a couple of good places that might be able to hook you up, if you're coming out for x-mas. Hit me up on pm. btw-i feel your pain
Old Dec 13, 2002 | 08:23 AM
blizz20oma's Avatar
I'm so hood
D'oh...I feel ya on the internship/funds note. Makes me think about moving back in with the rents for $ purposes...ugh. One day the experience will pay off...
Sometimes cars can just be a pain at the wrong times, for the wrong reasons. One of the major reasons I've held off on modding my daily drivers at all, even though I'd like to. Good luck on getting the max back into shape.
Old Dec 13, 2002 | 08:30 AM
slimer's Avatar
yeah, like when i hit a pothole on the highway on monday and bent my oem rim and blew out my tire? is that what youre talking about? Damn Penndot and their ishy roads.
Old Dec 13, 2002 | 08:41 AM
pittsburgh roads cant touch detroit roads. Absolutely blow. It seems to be acting like a catalyst to the demise of my car. Im at 82k.
Old Dec 13, 2002 | 09:16 AM
SuDZ's Avatar
[BRent, groceries, gas, car payments, cell phone, haircuts. [/B]
Shave your head like me. I havent paid for a haircut since I was 12 Only cost me the clippers hehe
SuDZ
Old Dec 13, 2002 | 09:41 AM
Re: Re: Sam feels like venting
SuDZ
i just do the buzzcut thing once a month, but left the clippers at home, and am not gonna purchase any. well im on lunchbreak now so at least that helps...mmmmmmm RAMEN noodles, be still my beating taste buds...
Old Dec 13, 2002 | 10:00 AM
SuDZ's Avatar
Re: Re: Re: Sam feels like venting
Gotta go easy on the Ramen though. That brick is loaded with salt and stuff.
SuDZ
Old Dec 13, 2002 | 12:39 PM
slimer's Avatar
have you been here lately? everything is under construction and theyve even shut down some bridges cuz its so bad. yuck.
Old Dec 13, 2002 | 01:01 PM
Stephen Max's Avatar
My maxima blows.
This from the 4th gen FAQs:
"My clutch pedal is too high/too low/wants to adjust itself...what can I do?
Get a flashlight and move back your seat. Get a 12 mm open ended wrench. Look above the clutch pedal and there is a threaded rod that also has ridges that run up and down the rod that goes into the fire wall and moves with the pedal. Find the 12 mm lock nut and loosen it. Adjust the clutch pedal release point and height by turning this rod. Do it slowly as it doesnt take much movement to change the positioning at all. DO NOT PRELOAD the slave operating cylinder, otherwise (if your clutch pedal wants to adjust itself, this is why it does it) the automatic clutch adjustment will be constantly adjusting the clutch pedal on you and it is VERY annoying and almost impossible to consistently race like that.
After you find a sweet spot, tighten down the lock nut.
Great, I did that, now my cruise control doesnt work... why?
While you're down there, you have to make sure you adjust the switch that senses the clutch is all the way "out" or engaged. Look infront of the clutch pedal and you'll see a switch with an electrical connector on it. Unplug the electrical connector, and simply screw the switch to adjust its height. The correct adjustment is that the switch will be engaged when the clutch pedal is all the way out."
Old Dec 13, 2002 | 01:05 PM
im gonna check that tonite. I think i might have found the clutch problem when i was searching. I have all the smptoms of a leaky hydraulic hose as well as maybe a faulty slave cylinder, but im gonna bleed it and change the hydraulic hose hopefully tonite. I found goop around the hose, but i alse see "sweat" on the tranny case. is this result of bad hydraulic hose, or is the slave cylinder leaking as well. Thanks
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Marc2theMax
Sep 28, 2015 08:13 AM
