Pretty Interesting Stuff about the LSD Manual Tranny's !!!
Old Dec 13, 2002 | 06:28 PM
matty's Avatar
My tranny went in my 96 Maxima so I decided to go with an LSD trans from an I-30...I found one from a 97 with 63K miles on it for $500 so I bought it...I find out that all i need to do is replace the drivers side axel and the pass side is the same as open diff. So I have the speed shop get me an axel from the local axel wharehouse--rebuilt...so about a week after Install its starts to leak at the drivers side axel housing even with a new seal and a new axel...so I have the guy put in another seal and its still leaks...I call raxels.com and talk to a tech and he said Nissan changed the splines in the differential gear in 95 and up years, and didnt advise all of the axel wharehouses around the United States that they did the slight change....So when you go to buy a rebuilt I-30 or Maxima LSD axel its the old configurations that there using for the old spline confifiguration causing leak and possible failure to the bearings and vibration through throttle...Now that must be whats wrong with mine cause I have vib in every gear at 2500RPMS and a slight leak out the axel...the old configuration will Click in, but will cause movement in the shaft, and slight leak and vibration (slight)
-Matt
Very good info, and Im still looking into it
Old Dec 13, 2002 | 06:41 PM
matty's Avatar
So the only way to get an axel for an LSD is to :
1) Buy the spline from Nissan and have an Axel Shop build you one..$$ Lot of money $$
2) Try to get a used axel right from the car that the tranny came out of, or same car with LSD..put that in the car, or have it rebuilt for $120..I called some places today...its about $150 used
-Matt
I hope this tech is right...cause there is another .org member that used to have my problem till he called raxels and solved his leak this way...but his brand new i-30 axel broke and raxels gave him the info about it, Solved
NO axel shop will have the right configurations for the Diff. sounds like a big slip up by Nissan
Old Dec 13, 2002 | 09:17 PM
KWheelzSB's Avatar
Great info!
I hope you're able to get a workable solution. . .
Ok, don't hate me, but. . .
AXLE = http://www.raxles.com/prod01.htm
AXEL = http://www.andgor.com/Gallery%20Pages/axelrose.html
Welcome to the jungle! Complete w/ Manson t-shirt - Fun for all ages! I love it!
Old Dec 13, 2002 | 11:45 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
well uhmmmm
ive had 3 broken driver side axles and i always get them replaced under waranty. Ive been using rebuilt from the day i got the tranny. havent noticed no leak and although it was semi hard to get the axle in, it goes in and its the right one....
Old Dec 14, 2002 | 12:37 PM
matty's Avatar
Well the thing is that maybe Nissan did tell some places the spec of the new splines but didnt tell some...Im telling you, the guy at raxels.com definetly knew what he was talkin about
Old Dec 14, 2002 | 09:57 PM
triax37's Avatar
Originally posted by Turbo95Max
well uhmmmm
havent noticed no leak ....
You haven't noticed no leak? So are you just refilling the fluid everyday? Kinda a waste of money, if you ask me - just fix the leak!
Old Dec 15, 2002 | 12:11 AM
hlh0501's Avatar
Once again i thank God for me being the luckiest person out there... my LSD tranny works beautiful/perfect with my old regular 5spd axles for months now! and also, no snapped shafts to date either KNOCK ON WOOD.
Old Dec 15, 2002 | 08:36 AM
Ramius83
So, with the LSD tranny, you are using your old 5-speed axles? This is so confusing lol, do I or do I not buy the axles when the tranny comes in lol.....
Old Dec 15, 2002 | 09:18 AM
matty's Avatar
I would get a drivers side axel, the Drivers side is noticably bigger and the other one with from your open diff will not Fit..there are two sets of splines on a locking diff drivers side axel and one set on an open diff
-Matt
Old Dec 15, 2002 | 10:40 PM
Turbo95Max's Avatar
maybe its juss raxles.com that have the wrong ones??? i deal through ARI, and even tho ive been unhappy with the quality of them..they are the right axles.
pktaske
May 6, 2016 07:49 AM
DrVee
Sep 4, 2015 12:18 PM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
