speaker removal ?
Old Jan 1, 2001 | 10:38 AM
maximumsportZ's Avatar
Lives in a 350Z
is there a site which will tell you how to remove the front speakers on the door and the rear decks ones??
Old Jan 1, 2001 | 11:32 AM
MacGyver's Avatar
I don't know where to find it online, but I went to the nissan dealer to get a part for my door a few months ago and the guy printed out a detailed copy of the door. It showed where all the screws were and how everything fit together.
Old Jan 1, 2001 | 12:21 PM
Washington DC Maxima's Avatar
Remove the two bottom screws-->>
at the bottom of the the door. Pop out the plastic piece on the arm rest of the door.. Remove that screw.. Pop/pry the plastic piece at the door handle then pry around the left and right side of the door. Then push upwards after all the plastic pry points have been pried away.
There rear dash..
Remove seat(pull the release tabs at the bottom corners of the seat) Unscrew(use a socket wrench) the two screws on seat back at the bottom corners. Remove plastic (by unhooking the center pass thru) to view screws holding the center of the seat back in place. Lift seat back upwards and remove. Remove rear dash light(pull on it a bit(not to rought!!)) disconnect it's wire connector.. Pry rear dashup at it's pry points(you may view where the plastic pry pins are by looking for the orange pins while inside the trunk(for reference))
All of this is from memory but I'm 85% sure it's accurate..
Old Jan 1, 2001 | 02:44 PM
Lives in a 350Z
hey thanks
i'll try that!
Old Jan 1, 2001 | 06:59 PM
Micah95GLE's Avatar
Re: Remove the two bottom screws-->>
Also, you need to pop the cover off of the courtesy light and remove the two screws inside of that and unplug the wiring harness. Once you get the door panel off, you can unplug the big wire harness to get the panel out of the way.
Old Jan 1, 2001 | 07:07 PM
Lives in a 350Z
aight
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
