rubber stuff on my window
Old Dec 16, 2002 | 01:52 PM
jdaadv's Avatar
I have some black stuff that has the consistency of melted rubber on my right rear window. It's stuck on there pretty good and I don't want to use a razor to get it off cuz I'll scratch the window. Any ideas on how to remove it? maybe some kind of solvent will get it off? please help!
Old Dec 16, 2002 | 01:54 PM
98BlaximaSE's Avatar
Re: rubber stuff on my window
Razor won't sratch the window if you use it right. Might want to try goo gone. Stuff worked well form removing stickers and such.
Old Dec 16, 2002 | 01:57 PM
MacGyver265's Avatar
Try a heat gun or a hair dryer and then use a plastic ice scraper. You could use a fresh razor blade on glass to avoid scratching it. A used razor blade will present more danger to scratching on glass. Try some acetone for a solvent, that stuff eats through most polymer based plastics so be careful you don't get it on anything else. Acetone is also highly volitile (means it evaporates fast) so use in a well ventilated area, and it is highly flammable too.
Old Dec 16, 2002 | 04:04 PM
95maxima's Avatar
i used a razor to take off some old tint on my car. the razor wont scratch the window if you use it properly.
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 24, 2015 05:03 PM
