Engine Coolant Temperature Sensor
Old Dec 16, 2002 | 02:06 PM
gabex's Avatar
I have a 95 maxima gxe w/ 96k miles, and today my check engine light was on. I checked the diagnostics and got 1 long, 3 short pulses which says Engine Coolant Temperature Sensor.. anyone know how to fix this?
Old Dec 17, 2002 | 09:31 AM
SE Maxima's Avatar
Re: Engine Coolant Temperature Sensor
you can always try resetting the ECU then see if the code comes back, it might not.
replacement is easy and well explained...either on this org or a related site, or a haynes manual. i don't remember exactly how to explain it or i would. you can pick up the sensor from AutoZone or a like store for ~$25. total time is less than 30 minutes, easy.
good luck
Old Dec 17, 2002 | 09:40 AM
Jepht20's Avatar
Custom User Title...
i think i payed roughly $40 for mine at a local nissan(stupid me should have ordered from one we get the discount). once we finally found which one it was, took about 10 minutes or so. do a search for it and you'll find many threads and write-ups. goodluck and do it before your car starts stalling.
Old Dec 17, 2002 | 10:04 AM
njmaxseltd's Avatar
Is your car having some start up issues? Replace that sensor and if your had starting problems, they'll go away too.
Old Dec 17, 2002 | 12:30 PM
gabex's Avatar
I reset my ECU and the Check Engine light went away. The only trouble I have starting my car is early in the morning or late at night when it's friggin freezing, and then it will stall the first time, and work when I give it a little gas..Im about to change my oil in the next couple of days.. so I guess replacing that sensor wouldn't hurt either..except my pockets, I lost my wallet in a movie Sunday night . .. Anyways thanks for the help
Old Dec 17, 2002 | 01:01 PM
njmaxseltd's Avatar
That will definately stop happening once you replace that sensor.
Old Dec 17, 2002 | 07:14 PM
SE Maxima's Avatar
come to think of it, my car hasn't had nearly as much trouble starting lately as it used to...i replaced my ECTS a couple months ago. i never knew that might have something to do with it.
i love this place, you learn something new all the time!!
MR2 T'd
Jul 9, 2021 05:06 AM
mvm062
Nov 30, 2020 09:00 AM
6spd4dsc
Mar 4, 2016 05:19 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
