lesson learned changing spark plugs
Old Dec 17, 2002 | 11:33 AM
kvzeyde's Avatar
I put new spark plugs in yesterday and thought I would share information with those members who have not yet put in new plugs.
1. When disconnecting the ignition coil harness connectors (gray body, green release latch with the arrow molded into it) it works well to place the tip of a flat bladed screwdriver on edge into the slot by the arrow and push with the screwdriver. When you push the latch with the screwdriver you will hear it click when it releases.
2. Use a 12 inch or so piece of rubber hose to hold the new plugs when you start threading them in place. This will prevent any chance of cross threading the new plugs. This is described in the Haynes Manual.
3. When installing the Phillips head/8mm bolts that hold the ignition coils in place, try putting some contact cement in the Phillips slot and some contact cement on the tip of your Phillips screwdriver. Let the contact cement dry for a couple of minutes before you install the bolts and the bolts will stick to the screwdriver tip and make it less likely that you drop a bolt somewhere in the engine compartment.
There are several good writeups which I found using search. Thought this might add to them.
Old Dec 17, 2002 | 11:38 AM
MacGyver265's Avatar
Those are some good tips for just about any car. Especially the contact cement thing. I can't tell you how many screws I've dropped through the engine compartment in various cars when working on them.
Old Dec 17, 2002 | 11:47 AM
gepetto's Avatar
Re: lesson learned changing spark plugs
3. When installing the Phillips head/8mm bolts that hold the ignition coils in place, try putting some contact cement in the Phillips slot and some contact cement on the tip of your Phillips screwdriver. Let the contact cement dry for a couple of minutes before you install the bolts and the bolts will stick to the screwdriver tip and make it less likely that you drop a bolt somewhere in the engine compartment.[/B][/QUOTE]
Why not just buy a magnetic screwdriver
Good writeup though. Thanks for the info.
Old Dec 17, 2002 | 12:19 PM
phenryiv1's Avatar
Mod her. Ate her.
Re: Re: lesson learned changing spark plugs
Good writeup though. Thanks for the info. [/B][/QUOTE]
Or magnetize any screwdriver by running a magnet up and down the shaft for a minute or so...or storing your screwdrivers with a magnet on the end...
Old Dec 17, 2002 | 12:55 PM
kvzeyde's Avatar
Re: Re: Re: lesson learned changing spark plugs
[QUOTE][i]Originally posted by phenryiv1
Good writeup though. Thanks for the info. QUOTE]
Or magnetize any screwdriver by running a magnet up and down the shaft for a minute or so...or storing your screwdrivers with a magnet on the end QUOTE]
Thanks for the magnet idea.......sounds less messy than the contact cement. The contact cement trick works with aluminum, brass, copper, etc. For steel, the magnet is the way to go.
mvm062
Nov 30, 2020 09:00 AM
The Wizard
24
Oct 1, 2015 08:47 PM
ag90fox
Sep 9, 2015 12:22 PM
minsbang
Sep 5, 2015 05:36 AM
sdotcarter
Sep 2, 2015 09:53 PM
