water pump replaced! - now timing chain is rattling
Old Dec 21, 2002 | 11:15 PM
idt512's Avatar
just got the water pump replaced and now the timing chain sounds like its rattling. Mechanic said the tensioner is worn out but I refuse to believe it since I brought the car in silent as a sleeping baby...what do you guys think? He suggests that I replace the tensioner, chain, and guides for an addition $200, and I said "what?, hell no!!"
Old Dec 21, 2002 | 11:34 PM
Sean97SE's Avatar
you shouldnt ever have to replace the timing chain. the dealer told me that too. If you needed it replaced the ecu would throw some sort of misfire code.
Old Dec 22, 2002 | 06:03 AM
njmaxseltd's Avatar
The tensioner does tend to get weak over time. To replace the pump, your mechanic had to release the tension on the chain. Most likely he did that by releasing the tensioner. Now that it's been played with, it's lost it's ability to keep the chain tight. It needs to be replaced. Tll your mechanic to replace it, you pay for the part and he eats the labor. (Labor is the biggest part of the job)
Old Dec 22, 2002 | 04:21 PM
SamMan23's Avatar
200 is pretty good price.
Old Dec 22, 2002 | 05:06 PM
m86stanggt's Avatar
Re: water pump replaced! - now timing chain is rattling
Hey,
I did the water pump on my car and when I started it the chain rattled for a few minutes then it went away after it pumped back up. How long have you ran the car since u did the pump.
Old Dec 22, 2002 | 07:06 PM
idt512's Avatar
The service manual says its normal for the chain to be noisy until the high pressure chamber fills up, but its been 2 days now and it still hasnt gone away.
Old Dec 22, 2002 | 08:39 PM
m86stanggt's Avatar
Hey
If it has not pumped up yet then most likely it is shot. Unless the guy who did it left the pin in it that takes the tension off the chain. but i don't think someone would forget that... just my .02...
Hondarydr
Dec 30, 2024 06:15 PM
maxinout93
Oct 27, 2015 01:29 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
