Help!!! May be buying 1997 maxima tomorrow
Old 12-23-2002, 02:22 PM
sammjordan's Avatar
whats crackin everyone?
i need your guys' help. i might be buying a 1997 maxima GLE with 65k miles for $7250. first of all, is this a good deal? second, what areas of the car should i look for problems, and what problems did the 97's have that i should look for? all help is appreciated thank you. peace
sammjordan is offline
Old 12-23-2002, 02:41 PM
Custom User Title
Nismo3112's Avatar
Thats a really good deal..
my uncle has a 97 also and hes got almost 90k on it, no problems
except regular maintenance, oil changed every 3k miles, and you are good for 200k
Problems: alternator recall
thats all i can think of??
Nismo3112 is offline
Old 12-23-2002, 03:59 PM
SamMan23's Avatar
run a carfax check or call lemonbusters to check out the car.
SamMan23 is offline
Old 12-23-2002, 04:05 PM
MDubya
CARFAX for sure. some deals are too good to be true....
ALso check underhood and ALL doorjambs to see if its been repainted or wrecked..
Buy from an older person.besttip.
Old 12-23-2002, 04:09 PM
Eric L.'s Avatar
Other unavoidable problem areas: starter, O2 sensors, knock sensor
Eric L. is offline
Old 12-23-2002, 04:37 PM
patel_anu's Avatar
the alternator might give you problems too but that can be changed under the recall for free....and thats a really good deal
anu
patel_anu is offline
Old 12-23-2002, 10:19 PM
MacGyver265's Avatar
I agree with everyone else. I own a 97 GLE with 112k miles on it and it runs great. Like everyone else says, check for signs of an accident and take a test drive. If you see an ECU code, make sure you check out the procedures for retrieving the code and pull it off the ECU. Some codes aren't that bad, like 0707 - Rear heated O2 sensor, my car had this and I reset the ECU and it never came back, or other malfunctioning sensor codes, but others can indicate something worse.
MacGyver265 is offline
Old 12-24-2002, 11:34 PM
krbga's Avatar
If you haven't already, check out some more info:
http://auto.consumerguide.com/auto/u...fm/id/2214.htm
krbga is offline
Old 12-25-2002, 10:01 PM
finny's Avatar
sounds like a real good deal as long as the car checks out alright. check it out and run a carfax and grab it if all good
finny is offline
Old 12-25-2002, 10:15 PM
Sports Button FTW
meccanoble's Avatar
that's a great price if the car is in good shape, no rips or anything. I paid a little more than what u did for my maxima and it was fully loaded like a GLE and had like a good 1,000 dollars in mods. However, i literally have twice the mileage of this car and tha'ts what's most important when trying to resale it. If the car hasn't been in an accident, and it has everything u want, i would go for it...don't have to worry too much about trans since its auto, even if someone bad drove the car, it can't be worst than someone killing a 5 speed trans...
meccanoble is offline
Samedi
08-13-2015 04:05 PM
jchronis2552
08-13-2015 07:48 AM
Superbform
08-11-2015 08:10 PM
silver_i35
08-03-2015 11:23 PM
Quick Reply: Help!!! May be buying 1997 maxima tomorrow
