97 maxima interior light not working when door is open
Guys I have a 97 Maxima with a partially functioning interior dome light. The problem is ever since I had the alternator replaced due to a recall, the interior light no longer automatically comes on when the doors are open. It does work when manually turned on via the dome light switch. I don't think the problem is specifically related to the alternator itself being replaced, but I am wondering was there a fuse blown or a setting changed somewhere during the process of switching out the alternator. If anyone has any advice it would be much appreciated.
Mark
Mark
Originally posted by CaLSoNiC
Are you sure the switch is in the correct position?
Mark
Check the door switches as well. If none of the doors will activate the light upon opening when the dome is on the correct setting, I would assume they activate a relay somewhere and it has either become unplugged or is toast.
unless they changed the 97, it is a 3 position switch. drivers side is on, middle is off but door activated and passenger side is totally off.
Originally posted by initsix
Whats switch are you referring to? The dome light has an on/off switch that is normally in the off position. The dome light _should_ go on even if the switch is in an off position. This is what is currently not happening.
Mark
Mark
Re: yes i second this
Originally posted by daroknessmonsto
Mark
Maybe you dont know your own strength and are so mad that there was a recall you just slam the switch and you totally miss the middle position!
My 97 se has this middle position, and unless maximas grow/evolve/a sexually reproduce nowadays i think yours has it too.
I think I may have found some info to go on based on this newsgroup posting I found through google.
http://www.se-r-list.org/new-archive...03/006945.html
Thanks to all that have responded.
-Mark
That isnt a "dome" light
the light behind your sunroof is your dome light, thats like a courtesy light or somehting, mine never turns on when my doors open either. your max is not broken.
Feel free to laugh at my stupidity the same way I laugh at the idiots on computer bulliten boards who ask moronic questions.
Thanks for your patience and time.
MAXSE5SPD
Aug 23, 2015 12:06 PM
kjm900r
Aug 5, 2015 07:14 AM
<---Laughing
