Got my AGX's !!!
Old Dec 24, 2002 | 07:57 AM
Nismo82's Avatar
Got my AGX's !!!
Finally. I will soon have my sprints on with them! How do you adjust the back skocks? There is no **** like the front ones.
Old Dec 24, 2002 | 09:14 AM
rmb's Avatar
rmb
Re: Got my AGX's !!!
Ummmm..... If they're real orange AGX's the rears should have a big plastic 8 position dial right on the outside of the housing. The fronts should have a 4-position setting built into the top of the strut rod adjusted with a little screwdriver.
_RMB
Old Dec 24, 2002 | 09:33 AM
Miasma's Avatar
Re: Re: Got my AGX's !!!
_RMB
i agree.
and you can change your sig now if you really do have AGXs.
Old Dec 24, 2002 | 10:20 AM
GlenH's Avatar
I think you are confusing the front ones with the rears.
The rears have a large **** on the side of the strut below the spring seat. The fronts DO NOT have a **** on them. Adjustment is achieved by using a small flat head screwdriver (supplied w/ the struts) and pushing and turning the adjuster on the very top of the piston shaft. If you look on the very top, you will see 4 numbers arranged in a circle.
Old Dec 24, 2002 | 10:46 AM
maxNYC's Avatar
Will the rear ***** be blocked by the strut boots?
Old Dec 24, 2002 | 11:20 AM
mforrest100's Avatar
Re: Re: Re: Got my AGX's !!!
Nope. Not at all.
Old Dec 24, 2002 | 11:40 AM
GlenH's Avatar
The rear ***** are located BELOW the spring seat. Thus, they are not anywhere close to the strut boots. The rears are easily accessible from below the car. Don't need to take the tire off or anything. Just crouch down, reach behind the rear wheel and turn the dial.
Old Dec 24, 2002 | 11:55 AM
Shoooter_j's Avatar
Re: Re: Re: Re: Got my AGX's !!!
Or if you have problems reaching the ****, jack the car up
Old Dec 24, 2002 | 01:06 PM
Nismo82's Avatar
Yup, I am
They are real, and I was back asswards.
Old Dec 24, 2002 | 01:12 PM
Nismo82's Avatar
Good lookin' out
Old Dec 24, 2002 | 08:12 PM
StygianMax's Avatar
When you install your rear shocks, make sure the **** is facing towards the centerline of the car & not the outside. It makes adjusting of the **** that much easier.
Old Dec 24, 2002 | 08:18 PM
Conrad283's Avatar
I need a truck
there should be little screw drivers that came with the front ones .... the adjustment is on the top it had 4 settings (1-4) once you put the AGX's on you'll see, you're able to adjust them by simply popping the hood ... the little screw drivers help adjust hope that helps
Old Dec 24, 2002 | 08:29 PM
ThurzNite's Avatar
how's that possible? I thought there's only 1 way to mount struts?
Jae
Old Dec 24, 2002 | 08:37 PM
Conrad283's Avatar
I need a truck
mine are facing forward
Old Dec 24, 2002 | 08:41 PM
spiff56747's Avatar
Jae
I'm pretty sure you can mount them either way. All you have to do is rotate the top part that has the two bolts that attach to your body, everything else is pretty much symmetrical.
I have my adjustment ***** facing outward, but I'm sure many people have them inward too. I guess its easier to adjust if theyre facing inward, but I don't really adjust them too much anyway.
StygianMax's Avatar
Jae
I believe you're right about the struts (which are on the front) but not the shocks which are on the rear. I'm actually going from what I read about someone else's post a little while back.
Old Dec 24, 2002 | 08:45 PM
StygianMax's Avatar
I have only adjusted my rear shocks when going to the 1/4 mile track. I crank it from 4 to 8. I find it's a bit hard to reach in to adjust the **** without jacking up the car a bit. Maybe I just have short arms.
Maxima_Joe
Nov 25, 2015 08:19 AM
maxima-junky
Oct 7, 2015 06:13 PM
Maxima_Joe
Aug 27, 2015 12:01 AM
mcros
31
Dec 26, 2001 03:24 PM
