no heat when idleing
Old Dec 25, 2002 | 06:59 PM
plurco's Avatar
my heater does not heat when the car is just idleing, why is this?
I have automatic climate control on my car which was set to 85 degrees, and it was sitting there for about 20 minutes.
Old Dec 26, 2002 | 08:24 AM
JustMaxin96's Avatar
Re: no heat when idleing
I have the same problem. It is only when the car is just sitting, when I drive I get heat. Can anyone help?
Thanks!!
Old Dec 26, 2002 | 08:34 AM
mzmtg's Avatar
Minister of Silly Walks
Is this after you start the car cold, on a cold morning? Or do you lose heat when you stop after the car is already fully warmed up?
Old Dec 26, 2002 | 08:39 AM
The temp. guage is in the middle, car is fully warmed up. But if I stop and sit there for a couple of minutes the heat just becomes cold. It is weird I don't know what the hell it is.
Old Dec 26, 2002 | 08:42 AM
njmaxseltd's Avatar
Check the Antifreeze level.
Old Dec 26, 2002 | 09:08 AM
Pearl99GXE's Avatar
I agree with njmaxseltd. Happened to me. No heat at idle. Radiator was half full or half empty, depending on how you look at things.
Old Dec 26, 2002 | 09:50 AM
kvzeyde's Avatar
I had an old Cadillac that did just the opposite......heat at idle but no heat when moving. I was a bad heater control valve. Don't know if the Max uses something similiar but it might be worth investigating.
Old Dec 26, 2002 | 10:29 AM
Re: Re: no heat when idleing
hmm.. heater control valve? I have never heard of that. Maybe someone else has?
Thanks for the replys!!
Old Dec 26, 2002 | 11:26 AM
mechanicaljoint's Avatar
mine did same thing...replace the thermo...no more problem
Old Dec 26, 2002 | 11:28 AM
Kashoggio's Avatar
that or there could be air in the system
Old Dec 26, 2002 | 11:39 AM
Paonessa
i agree with mechanicaljoint. check the thrmostat
Re: Re: Re: no heat when idleing
hu? What do you mean cold air in the system?
Old Dec 26, 2002 | 12:00 PM
Pearl99GXE's Avatar
If it was the thermostat, it would be cold all of the time. Their cars put out heat when it is moving. After you changed the thermo, you had to refill the coolant anyway.
Check your coolant lever first.
Old Dec 26, 2002 | 12:02 PM
Pearl99GXE's Avatar
Check your coolant lever first. [/B][/QUOTE]
Coolant LEVEL.
Old Jan 11, 2003 | 12:57 AM
multiplexor's Avatar
so was it the collant level?
i am having the same problem now...
when idling for about the length of a stop light time, my hot air turns cold. If i rev it to 1.5k - 2k, it gets super warm again...
everyone thinks it's the coolant level?
I checked mine this morning and it was to the top. (just to be sure)
I simply pop open that metal cap right in front of the car under the hood... and see if i see fluid right? It was to the top for me...
maybe it needs replacing?
tarun900
19
Dec 20, 2021 06:57 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
