stock loaded 96 SE climate control problems
Old Dec 26, 2002 | 03:15 PM
Lime's Avatar
Okay, gotta sk for my mom. She has a stock 96 SE, loaded. The climate control is freaking out; the heat doesn't come out of the bottom vents anymore. Is this electrical or mechanical? Anyone know? I'm not an auto-climate-control person.
Old Jan 2, 2003 | 08:04 AM
Lime's Avatar
no one has any idea on this?
Old Jan 2, 2003 | 05:55 PM
Nismo3112's Avatar
Custom User Title
Listen for the servo motor (underneith dash by gas pedal) to move when you switch to the bottom positions..does it work in the other positions? If it works in the other positions the motor should be fine.
Old Jan 3, 2003 | 03:37 AM
96shogunmax's Avatar
I got one if you want it, it just doesnt light up like the buttons dont but the screen does work perfect you could swap the bulbs out. if you want it ill hook you up . you pay only shipping?
Old Jan 3, 2003 | 07:29 AM
njmaxseltd's Avatar
Isn't there more then one servo motor?
Old Jan 3, 2003 | 07:22 PM
Nismo3112's Avatar
Custom User Title
Yes. There are i believe 2 or 3? one is for switching from cold to hot, the other is for switching between top/floor/defrost/ etc etc.
Old Jan 4, 2003 | 05:36 AM
Lime's Avatar
someone is helping me by sending me a wiring diagram for the fans and climate control...hopefully I can tell more by that...more news soon. Tomorrow I will be at my mom's anyway, changing her oil.
Old Jan 5, 2003 | 08:22 AM
Lime's Avatar
okay...this is what I gather from the FSM, from which someone kindly emailed me the climate control section:
MODE DOOR MOTOR
The mode door motor, attached to the heater unit, directs
discharge air to various outlets. It is controlled by the auto
amplifier.
Now this is located behind the dash...does anyone know how to get the dash off there? I've never taken the dash off a Max before.
Old Jan 5, 2003 | 02:01 PM
Nismo3112's Avatar
Custom User Title
You can get to one of them by removing just the entire center console.
I believe it sits on top of a black or white box (heater unit) and it is right behind the auto amp.
You can also remove the entire dash..which is a pain in the ****!
Old Jan 7, 2003 | 04:54 AM
Lime's Avatar
I'm not sure how to remove the console; I guess I'll have to look into it or tell her to take it to the stealership.
Old Jan 7, 2003 | 05:23 AM
Sprint's Avatar
http://forums.maxima.org/showthread.php?threadid=60393
MikesChevelle
Mar 2, 2021 11:32 AM
homeyclaus
Sep 3, 2015 06:15 PM
asianstyle
Aug 24, 2015 08:29 PM
