help help help
Old Dec 30, 2002 | 02:57 AM
devious max's Avatar
help help help
My transmission just died today i have a 98 max. I was wondering which is the best transmission to put on my max. Do anyone have a hookup for the transmission or installation? Any suggestion is helpful so please help me and thank you in advance. Need my max working for commuting to school and work. P.S. how much money do i need to borrow to spend to fix my transmission problem?
Old Dec 30, 2002 | 05:57 AM
blakkrob's Avatar
Try here:
www.Car-Part.com
Old Dec 30, 2002 | 06:06 AM
Sprint's Avatar
thats interesting.. my cousin's just blew too.. we are probalby replacing it this weekend..
i am guessing tranny will be $650...
and if you go to a shop they will probably charge you $600 labor...
so you are looking at $1300
Old Jan 1, 2003 | 09:34 AM
what the difference between a locking and non locking transmission and which one is better for the maxima
Old Jan 1, 2003 | 09:46 AM
Lime's Avatar
locking refers to the torque converter in an auto transmission. The torque converter electronically "locks" into the overdrive gear to save gas mileage, for example.
It's an electronic solenoid basically that controls the torque converter to save gas; it won't allow the TC to slip when gentle accelleration is applied. All about fuel economy (blah)!
Old Jan 1, 2003 | 02:17 PM
WizzaMax's Avatar
I am selling a transmission, but it is a 5 speed from a 97 non-LSD...let me know and it is in the FS 4th Gen thread under 5 speed conversion parts...
your profile does not say if you have a manual or automatic.
Old Jan 2, 2003 | 09:02 PM
which transmission is better lsd or non lsd and what the difference and where can i find one used near new jersey
Old Jan 2, 2003 | 10:49 PM
Black97SE's Avatar
VLSD is better. Try car-parts.com this is where I found mine. Here is a little write-up explaining what a VLSD is and does. Hope it helps.
"Why is a Limited Slip Differential(LSD) better than an open differential? A LSD is better because it allows power to be applied to the ground in a more controlled fashion. In an open differential setup if one wheel begins to spin faster than the other, more power is transferred to the wheel that is spinning fastest (this is a problem when you dump the clutch for instance.. because you spin one wheel faster, more power is transferred to that wheel, making it spin even faster which transfers even more power spinning it faster... this perpetial cycle only ends when the spinning wheel decides to grip the pavement). This is fine for the average driver because they won't worry about how quickly and affectivly his or her engine will get it's power to the ground. For sports car drivers, this matters. A LSD (in its various forms that I will discuss later) wheel try to keep the power output of each wheel balanced equally, ie if one wheel begins to spin faster than the other, more power is transferred to the wheel that is spinning slowest. Now that the differential difference is as clear as mud we can move on.
How does a Viscous LSD(VLSD) work? each output shaft of the differential is tied together by a device known as a viscous coupling. This is basically two slotted discs that have a silicon fluid between them. If the discs are rotated at a speed that varies relative to each other this produces friction which heats the silicon fluid up. The silicon becomes more viscous as it's temprature rises. There will be a point where the silicon will become viscous enough to hold the two discs together (this is why the discs are slotted, it is so the silicon will have something to grip to)." This quote was taken from 240sx.org.
Old Jan 4, 2003 | 08:13 AM
thank you black97se is this idea apply to automatic transmission also?
Old Jan 4, 2003 | 12:38 PM
Black97SE's Avatar
Yes, look at car-parts.com for a A.T. Locking differential transmission for either a Maxima or a Infiniti I30, but know might be a good time for a 5speed swap if you want. Do a search for 5speed conversion if you want some info. on it.
