Will the Frankencar mid-pipe and Stillen pop-charger work together
Old Jan 4, 2003 | 01:57 PM
D-sta's Avatar
I did a search and couldn't find anything that gave me a straight answer to my question. My friend has a 97 Max and wants to order the frankencar mid-pipe, but before ordering he wants to know if he can use the Stillen intake with the stillen bracket or would it require modification to fit with the mid-pipe? If he keeps the stillen will he have to use another support bracket?
Old Jan 4, 2003 | 02:05 PM
TheMax95's Avatar
Re: Will the Frankencar mid-pipe and Stillen pop-charger work together
Sure it'll fit. The Stillen pop goes on the MAF sensor with the MAF adapter included. And the Frankencar midpipe goes from the TB to the other side of the MAF. Many people have this setup for their intake.
TB > coupler > midpipe > coupler > MAF > adapter > Stillen pop
Old Jan 4, 2003 | 02:07 PM
D-sta's Avatar
Re: Re: Will the Frankencar mid-pipe and Stillen pop-charger work together
so the bracket will still sit in the same place?
Old Jan 4, 2003 | 02:11 PM
TheMax95's Avatar
Re: Re: Re: Will the Frankencar mid-pipe and Stillen pop-charger work together
'bracket', you mean MAF adapter?? Yes it goes in the same place.
Old Jan 4, 2003 | 02:17 PM
D-sta's Avatar
Re: Re: Re: Re: Will the Frankencar mid-pipe and Stillen pop-charger work together
The Stillen intake comes with this big bracket that bolts to one of the stock bolts where the bottom portion of the old intake box use to sit and the other bolts up to one of the MAF bolts, and it's function is to act as a support for the pop charger. Maybe if you can answer this I would be able to figure it out, is the mid-pipe and the section being removed from the car and being replaced by the mid-pipe the same length?
Old Jan 4, 2003 | 02:23 PM
TheMax95's Avatar
Re: Re: Re: Re: Re: Will the Frankencar mid-pipe and Stillen pop-charger work together
Originally posted by D-sta
Is the mid-pipe and the section being removed from the car and being replaced by the mid-pipe the same length?
OH , I know what you mean now but to tell the truth I'm not sure. Try measuring. If it's not the same length maybe you can just eliminate that bracket support thing. It's not NEEDED. The filter should fit just fine, I've seen it before.
Old Jan 4, 2003 | 02:39 PM
D-sta's Avatar
Re: Re: Re: Re: Re: Re: Will the Frankencar mid-pipe and Stillen pop-charger work together
thank you
Old Jan 4, 2003 | 06:09 PM
ardika's Avatar
Re: Re: Re: Re: Re: Re: Re: Will the Frankencar mid-pipe and Stillen pop-charger work together
I have this setup. They will fit. I have a 97 GXE with f.midpipe and s.k&n with bracket.
Do they fit? Yes.
Do you have to align the midpipes to make them fit? Yes.
Bottomline: They will fit together with some effort in arranging the midpipe connections.
You will know what I am talking about when you install these two.
Old Jan 4, 2003 | 06:53 PM
D-sta's Avatar
thanks for the warning
Old Jan 4, 2003 | 10:22 PM
Dstyle's Avatar
i have a stillen pop intake, and was thinking about doing the mid pipe. i like the sound of my intake now, but heard that the mid pipe makes it louder (since its removing a resonator). how much louder is the intake with the midpipe. i dont mind an increas upon WOT, but would be annoyed if it droned while crusing at normal speeds or on the highway.
Old Jan 4, 2003 | 10:37 PM
Nismo's Avatar
the midpipe will make it sound more deep and throaty rather than the weak "waaaaaa" from just the pop intake alone. no droning at all, just better sound
Old Jan 4, 2003 | 10:52 PM
TheMax95's Avatar
At normal cruising you barely hear it below 2k rpm. 2k and up WOT, it just screams. God I love it!!!!
Old Jan 4, 2003 | 11:48 PM
syc's Avatar
syc
I got JWT+midpipe and I think JWT alone make the deeper and throaty sounds than the JWT+midpipe.
Since JWT and Stillen pop are almost the same (some people said the stillen pop is even deeper), I don't agree that the midpipe will make the sound deeper.
However, I DO agree the midpipe is much louder.
Old Jan 7, 2003 | 09:43 AM
jerzeeMax's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Will the Frankencar mid-pipe and Stillen pop-charger work together
Do they fit? Yes.
I have this setup too. The bracket does fit fine right where it is. Just make sure you don't tighten any of the brackets on the couplers until everything is aligned. You're going to have to do a little bit of twisting and turning but everything does fit, pretty snugly too.
Old Jan 7, 2003 | 09:52 AM
D-sta's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Will the Frankencar mid-pipe and Stillen pop-charger work togeth
thanks
jerrod99_se-l
Aug 27, 2015 08:27 PM
cheftoo
Aug 20, 2015 05:17 AM
Team STILLEN
Aug 10, 2015 04:29 PM
kenc15
Aug 5, 2015 08:29 AM
