99' max SE ,,,indiglow gauges
Old Jan 6, 2003 | 07:32 PM
Argentina's Avatar
ok, i have bought 3 different kinds of reverse indiglow gauges.. every single time i go to install them...they never ever fit on properly.. either the holes dont line up or there isnt a hole for the tempiture gauge..can anyone help me with this problem... like where to get them or something i could do?
Old Jan 7, 2003 | 12:15 PM
JPMax's Avatar
What's next!?..
gauges for the 99 seem to be hard to find.
Have you tried the ones at SouthwestAutoworks.com? I believe delio(one of the moderators) has them on his 99.
Old Jan 7, 2003 | 12:25 PM
D-sta's Avatar
"Boludo".....
I just installed gauges for my friends 99 SE-L and got them of SWA, and the fit was perfect. This is the webstie www.southwestautoworks.com talk to Alex
here is a link to the product itself http://store.yahoo.com/southwestauto...smaxrevi1.html
Good luck!
Old Jan 7, 2003 | 02:38 PM
Nore474's Avatar
how hard are they to install? and much did you pay for yours
Old Jan 7, 2003 | 02:55 PM
D-sta's Avatar
It's pretty hard to explain the whole process, first you need to pop out with a small flat-head, the cruise control, dimmer, security little blocks and the other one which I forget what it's for but there are four in total. There will be a couple of screws behind those blocks so you will have to remove them and be careful about not dropping them in there, it might take you a while to find them. Then remove the two phillip screws located at the top of the cluster and once those screws are removed and the steering wheel is moved all the way down, the cluster cover should come out. Then you will see the plastic casing of the cluster and the phillips screws that keep it in place, you need to remove those and the cluster will become free enough where you need to disconnect the disconnections from the back, be careful don't force anything but they should come out easily. Now once you disconnect the connections the cluster becomes free and you can take it out. Separate the cluster clear cover from the cluster itself and then once you do that you are ready to lay the ones over it. I used clear tape to make the gauges sit in place, it was easy. Then you need to find the wire that is connected to your parking lights so that you can tap into them and give the new gauges life, you will need a test light. Then you need to make some little cuts at the top of the cluster itself where the new gauges are, so that the wires from the new gauges can fit through when you put the clear cluster cover back. Put everything back in the reverse order in which you took it out. Good luck and if you search you might find other instructions with pictures.
Old Jan 7, 2003 | 06:07 PM
JPMax's Avatar
What's next!?..
There's a nice writeup with pictures at www.MaximaDriver.com
The 99 set at SWA was $70 I think.
Old Jan 7, 2003 | 08:33 PM
99maximagxe's Avatar
is the 99 gxe same as the 99 se. I bought indiglos from ebay never took an effort to install them but now im afraid it might not fit. anyone bought indiglos from ebay and installed it on a 99 gxe.
Old Jan 7, 2003 | 10:06 PM
D-sta's Avatar
that's an excellent write-up with pics
Old Jan 8, 2003 | 05:20 AM
MaxMoJo's Avatar
Former Sponsor
Gauges are different fit from 98 to 99?
Are there two different ones available at SWA, one for 98 and one for 99 or is it one set that fits both?
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
