JWT ECU installed
Old Jan 7, 2003 | 07:00 PM
A-Ron Max's Avatar
Just put it in today. Really a great mod, my car pulls a lot better up until about 5k RPM's. I am looking forward to getting my MEVI next week so I can take advantage of the higher rev limiter. Who knows, with the new manifold I may be a contender for the fastest N/A I30.
Old Jan 7, 2003 | 07:28 PM
Confused's Avatar
Permanent Maxima.org Resident
no mil codes? have you checked for any codes that don't illuminate the mil?
Old Jan 7, 2003 | 07:33 PM
Toolrocks's Avatar
do they program the ECU differently for use with the VI or do they leave it the same? Meaning, once the VI is activated it crams more air into the cylinder, does the stock ECU compensate and add more gas, will the JWT? I just installed my VI about a month ago and am getting it dyno'd in 3 weeks - I want to see if it's running lean after 5k. Did you buy it new?
Old Jan 7, 2003 | 07:50 PM
j_bryan's Avatar
Good questions I would like the answer to as well.
I thought the stock ECU had a fixed set of parameters for wide open throttle.
Old Jan 7, 2003 | 09:35 PM
98maxsel's Avatar
yea me too.
Old Jan 7, 2003 | 09:53 PM
I30tMikeD's Avatar
Get that sucker to the track.
Old Jan 7, 2003 | 09:54 PM
Nealoc187's Avatar
SLOW
It does have a fixed set of parameters, and those parameters run rich. The aftermarket ECUs both lean out the mixtures (and advance the timing) to make more power, but they are both said to be on the conservative side still, JWT's especially. I would have no worries about running to lean, but a few dyno runs with a wideband O2 sensor should put all those fears to rest.
Old Jan 7, 2003 | 10:40 PM
A-Ron Max's Avatar
Sorry i took so long to reply, but yes i checked the ECU and there were no codes thrown out (I was a little afriad since I was using a 96' Maxima ECU on my I30). This modification definitely has some nice gains on its own, but it seems like it was made to work with the Variable Intake manifold. Also it is kind of nice to know that I have the chance to have a ECU controlled nitrous kit if I want (although the possiblity for an NX kit is now out of the question).
Old Jan 8, 2003 | 05:46 AM
Confused's Avatar
this should not be a problem since in effect your are not adding more air or "boosting" but rather simulating shorter intake runners.
QueensMAX
Sep 15, 2015 04:14 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
