does the brand of RSB really matter?
i'm going to buy rear sway bars... and i was just wondering if there any difference performance wise.. bewteen the stillen one (for $230) and the addco one (for $175). i realize that there is a weight and price difference... but is the stillen RSB work better, or is it for bragging rights??...
Yes, it does matter. The Stillen bar is adjustable with very noticable effects. The Addco is not adjustable, but it is cheaper. I have adjusted mine once and will adjust it again. I am very satisfied with mine, even though I don't like to recommend Stillen.
Addco's bar is adjustable as well. However the Stillen unit is more adjustable.
If your a tinker with it kinda guy get the Stillen. Personally I don't enjoy laying on my back working a socket wrench. I've gotta addco it works just fine. Either way you go... Get one... and dont' forget.... Enjoy the ride...
Wizeguy
Wizeguy
I think that the Stillen is a bit more responsive since it doesn't come with bushings. The Addco comes with four polyeurethane bushings, which might cause the RSB to be a bit less effective (a bit meaning not even noticeable), but it will effectively damp out the creaks and groans an RSB might make.
Both the Stillen and Addco are great RSBs. Neither is really better than the other, so just buy by price. I have the Addco bar and I think it is excellent.
Sorry Eric I will have to disagree with you >>>>>
if the Addco comes with the polyurethane bushiings thenit will actually make the bar more responsive because it will not deform like stock regular rubber bushings. Infact most people will switch to the polyurethane bushings to make the car handle better. The rubber bushings are more quiter and will absorb more motion before letting the swaybar do its job.
Re: Sorry Eric I will have to disagree with you >>>>>
someone correct me if i'm wrong here.
Dan
I stand by Eric L.'s comments, they are right on.
Wizeguy
I just popped on a Stillen Rear Sway Bar this weekend. It has no bushings on it at all the blue clamps literally just clamp around rear trailing arm that connect to the wheels. As for the adjustablity I was surprised to find out that consists of two possible sets of wholes to attach to the clamps and that's it. I would have thought (especially for the dough) that they would show you the millimeters or something.
adjustability
There is more than just which holes to mount the bar through. You adjust the bar by moving the entire RSB fore or aft of the axle. I installed mine about 2" past the axle the first time & placed about 1/2" pas thte second time. It made very noticeable difference. The car feels very neutrall now, where as the first position made the car feel like oversteering. I don't think that the Addco can move that much, though I have only seen pictures of one.
The plate you refer to is on the 2k pace car. Not exactly a consumer option here. SCC has an issue with a review on the Pace Car and a clear shot of the welded beam.
Also, I don't think that would have nearly the effect of an RSB. Correct me if I'm wrong.
Re: adjustability
I used to have the Addco one and help with body roll and reduce understeering, but if I were to get another one I would get the Stillen one or one of Stillen knock-off ones on Ebay (like $135) that don't use the bushings. Bushings are nice, but I like the metal-to-metal rsb because I want the rear end to be more solid and have more adjustability to increase oversteer.
Oh, and IMO there is a difference between Addco and Stillen. The stillen is .5" larger in diam which is a huge compared to Addco. I'm about to pull off my Addco and replace with Stillen next week.
mkaresh
03-12-2018 06:48 PM
knight_yyz
11-01-2015 01:34 PM
Stagnet04
10-11-2015 08:16 PM
