Changing brake pads...but have question
Old Jan 8, 2003 | 04:11 AM
elcid's Avatar
Ok well seems that I have grinded my front pads or atleast the fron right pads to ****. NO clue what happened anyways...Just wondering if there are any screw on the back of the calliper that I have to turn to bring the piston back. I know you ahve to screw the rear callipers back. Anybody know if this is also required with the fron ones? Thanks!
Old Jan 8, 2003 | 04:29 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Re: Changing brake pads...but have question
no screws, just use a c clamp to push the piston back in.. make sure you do it evenly. Also make sure you've taken the cap off your brake fluid reservoir
Old Jan 8, 2003 | 04:33 AM
WifesMax's Avatar
I, too, just did rear rotors/pads, discovering that you have to "screw" the piston into its retracted position. Any thoughts as to why the front pistons would compress with a clamp but the rears require "screwing around"?
Old Jan 8, 2003 | 04:51 AM
elcid's Avatar
Thanks!!! I'll get on that after work, can't stand driving around in my parents mini van...the ish feal like it's going to tip everytime I take a turn!
Old Jan 9, 2003 | 11:19 AM
sislen's Avatar
brakes
The rear ones require rotation while compressing the piston because they can be operated by the emergency brake cable, or the brake fluid.
rbuswell
Nov 17, 2016 04:54 AM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
