#$!@# CEL Codes 03 04 - 07 05
I bought a 97SE used a few weeks ago and I tested the ECU tonight (no light on though) hoping to find nothing, yet I got a definite 03 04 (knock) and 07 05 (EVAP control or something). What do I do?!!?
Derek
Derek
Re: #$!@# CEL Codes 03 04 - 07 05
Derek
Derek
Re: Re: #$!@# CEL Codes 03 04 - 07 05
Originally posted by SonicDust187
First fix the 0705 code, 0304 is a ghost code and should go away after you fix 0705 and reset the computer.
Re: Re: Re: #$!@# CEL Codes 03 04 - 07 05
I have read 07 05 could be as simple as tightening or getting a new gas cap. If I do that and then reset the ECU, will the CEL come on if the code is thrown again?
for a while -- when you release the gas cap, do you hear the
pressure "hiss"? if you do, it's prolly not the gas cap.
Reset the computer...check back in a week, and a week after that --
if the code is there, then start investigating...
my $0.02,
FLO_BOY
I reset the ECU and drove for about 20mins. I then checked it and the 07 05 code went away but the 03 04 remains. My idle is between 500-600...not sure if that matters. Gas mileage isnt too great either using 91 octane (highest available). Is it knock sensor replacement time for sure? Is this something a 17yr old boy can do himself with limited car knowledge? If so, detailed instructions would be great!
go to my website (look at my profile at the left here) and it shows
you where the sensor is, and what it looks like...website may have
exceeded daily limit, but, give it a try.
you'll certainly need a socket set with a "u-joint" swivel head (forgot the name of it...). The sensor itself is kinda pricey...you'll be pis$ed when you see how small this thing is!
other than that --> SEARCH --> I know for a fact that this will be in here.
FLO_BOY
Originally posted by FLO_BOY
It's not THAT hard -- unless you have monster hands...
FLO_BOY
FLO_BOY
Is it a knock sensor for sure? Could it be o2? Any way to check before I waste the $130+ on knock? I just got this car and was hoping for it to be reliable....so what should i do?
couple things to think about:
-- Does your car feel sluggish? I know you've had the car for only a short time, so, this is a tough one...
-- Reset the ECU...wait...see what happens....
-- give in...replace the sensor.
while you could replace an O2 sensor -- which one would you change?
There are a couple of O2 sensors, so, it would be a crap-shoot to pick one...atleast with the code, you know what sensor to swap.
Not changing your knock sensor (if busted) will give you poor gas mileage and less power as your timing will be retarded (slowed down, not handicapped
)hope this helps.
FLO_BOY
I dunno...your car is reliable (or should be)...the Knock Sensor is not. MANY MANY people on here have had to change their knock sensors.
hope this helps.
FLO_BOY
)hope this helps.
FLO_BOY
Mileage is crappy and at low RPMs acceleration seems sluggish, but thats with no comparison. After reading through 49 pages of search for 'knock sensor' I came across a problem. Im in CA and most likely have a Cali-spec...I have read this has a swirl valve in the way which requires you to take a manifold off...is this true? If so, I think this repair would be too much for me to do...ideas, help, anyone in Bay Area that would do it for cheap or just help me out? Anyone? Thanks!
jmlee44
Oct 2, 2022 02:13 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
