Installing Tips Rear sway bar
Old Jan 4, 2001 | 10:20 AM
nizmolee's Avatar
Anyone got good pictures of installing this sway bar? The shop talk doesnt have any good pictures of how to install it. Thanks!
Old Jan 4, 2001 | 12:26 PM
96BLUMAX's Avatar
Its so simple. Just have the bar facing forward and attach it in all four places. Once you get under the car, you'll see how to do it.
Old Jan 4, 2001 | 01:00 PM
Maxfreak
Where did you get those Z3 fenders, there tight. Anywho when I tried to install my Addco sway bar I first tried to do it with the tires on and the car lifted, I soon realized this was the hardest way possible. Take the tires off and set the sway bar underneath the car to where you think it should be and attach the bar to the beam loosely, put the tires back on and lower the car to the ground to get the suspension to where it would normally be. Tighten up the bolts on the bar and you should be ready to rip. I'm sure this applies to the Stealin(Stillen) bar as well. Everything bolts up to where it should with relative ease. It's pretty cake, just a little time and patience.
Old Jan 4, 2001 | 01:41 PM
y2kse's Avatar
Check it out, nizmolee . . .
http://grprete.jnet.net/Greg's%20Gar...Roll%20Bar.htm
Old Jan 4, 2001 | 02:57 PM
nizmolee's Avatar
Thank You Max guys. I ordered my addico one from Cattman. The only thing is that it doesnt any instruction. I'm not sure how each bolt clamps up and stuff. I'm going to run down to my friends car and check it out. thanks for the help
Old Jan 4, 2001 | 10:30 PM
turbolaw99's Avatar
Check out the MegaMax website under owner links.
homeyclaus
Sep 3, 2015 06:15 PM
ef9
Aug 27, 2015 07:21 AM
Dasmith
Aug 25, 2015 10:15 PM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
