speaker install
hope this helps
well, the front doors are pretty easy. I only did them like 5 times already playinmg with my crossovers and door handles. Just go to the home page of the ORG and go down to "shoptalk" and then go to "modifications" then I30 door handles" This will show you how to take off the front doors. As for the back, its really not that much of a pain. Here is some instruction:
1) Under the back seat there is two small clips(center of each side, tucked under) un-clip them and lift out the lower seat.
2) Then there is four 10mm bolts to take off as well.
- Two at the lower corners of the back part of the seat
- the other two are under the leather flap in the square opening to the trunk.
3) Lift out the back portion of the seat, be careful not to scratch the door jams when pulling it out of the car.
4) Under the rear lid there is 5 clips like in the door panels.
5) Look under the rear lid from inside the trunk and push up the two orange clips(they are between the two bars at the top, very small looking, but noticable)
6) Inside now there is 3 left
- one in the center front of the deck lid
- two others at either side near the seatbelt panels
7) Here is the tricky part, you have to lift the center of the rear deck lid and at the same time press the far right and left corners down (one at a time) to un-hook the lid from the rear panel on the sides(where the rear window meets the back panels)
8) Now remove the speakers be sure to secure them good or else you will have rattles like i did!!
9) Go in reverse when finished
10) your done and enjoy the new speakers.
Mar 12, 2020 12:06 AM
popdedop
Sep 11, 2015 11:17 AM
