Door mirror defogger for 1995 maxima
Old Jan 11, 2003 | 08:33 AM
chris j vurnis's Avatar
Hi all:
I did some searches and did find some references to people having heated mirrors or defoggers. At first I thought these were available only on later years of the 4th gen or only on certain trim levels like SE or GLE.
I just looked in my service manual and found a reference for a door mirror defogger (page BF-40 in 1995 service manual)
Seems like some fuses and relays control it all. Was this an option or did all 1995 models have it? As far as I can recall, my door mirrors always have condensation buildup on a cool morning. The condensation doesn't go away until driving for a while or unless I wipe it off.
Either it was optional and my car doesn't have it or my stuff is broken. I'll see if I can find anything when I check my car.
Old Jan 11, 2003 | 12:58 PM
DerekJ212's Avatar
This was an option. If you have heated seats, you should have this defog your door mirrors when the rear defroster goes on. If you dont have heated seats, I believe youre out of luck.
Derek
Old Jan 13, 2003 | 09:32 AM
thammel's Avatar
heated dorr mirrors
Hi,
I have a '95 Se that came without the heated option. Yes, it was an option and along with the way options were (and still are) bundled, I chose not to go for it. But...I bought the heated mirrors, installed the realay and ran the power wire so that I now have the option. It's definitely a doable job and is well worth it. They come on with the heated rear window defogger and go off at the same time. I did a number of other retrofits to make the plain SE even better. Like I installed a variable intermittent stalk, put in the woodgrain and drawer, put in the bose speaker covers, installed a windshield washer tank with low fluid sensor, put in an alarm system and a remote trunk release (rocker switch in the dash), installed a cd player and upgraded all the speakers to MB Quarts - and put tweeters in the little black triangles at the front botton of the front doors. So...there's a lot you can do to improve your Max.!
Good luck!
Tom
Old Jan 13, 2003 | 10:26 AM
BluFlame's Avatar
do you have any write up for this retrofit? or any pics?
halfpol
Oct 17, 2022 12:16 PM
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
halfpol
Aug 5, 2015 08:24 PM
wpr
Aug 5, 2015 03:28 AM
