problems after painting calipers..
I asked a friend to paint my calipers for me today ( i suck at painting anything) he said he would, and now when i get on my brakes it seems like i have to put more pressure on the pedal to stop. could he have gotten paint somewhere he shouldn't have? what can i do to solve this??? it seems like my pedal is just spongy...Thanks for all your help...
Mike
Mike
Re: problems after painting calipers..
Mike
Mike
You probably just need to bleed your brakes.
Mike
Mike
Worse case though, change the pads out and either turn or just clean the rotors with acetone + a real light sandpaper.
-RMB
Re: Re: problems after painting calipers..
Originally posted by rmb
High-temp paint on the rotors would be bad. Or if he painted the edges of the pads themselves... also bad.
-RMB
-RMB
thanks so much...this is really worrying me...will take a look and see. he used just bronze spray paint from autozone for the calipers...what if it is on the back of the pads, like on the backing plates or stuck between the pad and caliper??? I have some clear coat high temp stuff- would you spray them with that too?
Once again thanks,
Mike
Once again thanks,
Mike
Once again thanks,
Mike
Once again thanks,
Mike
Answer my question - did you remove the calipes from the rotor??
it looks like he neglected to do so. i could kill him. the only reason i asked is because i can't paint anything without screwing it up and he painted his.
Mike
Mike
If not, that cancels out the brake bleeding theory.
I just talked to him and he said that he removed the one on the drivers side, but then decided to put it back on. The brakes feel some better, or i may just be getting used to it. would i still need to bleed the brakes??
Mike
Mike
Mike
Mike
IanS
-RMB
-RMB
Re: Re: Re: problems after painting calipers..
Originally posted by venompwr2
why is high-temp paint bad??
Your car will not brake properly until it is removed.
D
doctorpullit
04-23-2017 05:35 AM
Hdnseek
09-09-2015 05:55 AM
