Replaced alternator
Old Jan 13, 2003 | 06:06 AM
BluFlame's Avatar
Replaced alternator
Battery light and brake light came on at the same time, I bought an alternator from autozone ($199) replaced it myself in 2hrs in cold.
while replacing I discovered lower rad hose was leaking coolant, i think thats why it went bad. I have 110k miles, i thought it failed too soon?
Old Jan 13, 2003 | 07:24 AM
malumax's Avatar
Re: Replaced alternator
110k is pretty good. Mine died at 50k...
There was a recall on some of the model years, but I dont know exactly what years. Do a search on the forum and you should be able to find which years. If your car is qualified then you can take your Autozone bill to Nissan and get a refund from them.
Good luck.
Old Jan 13, 2003 | 08:37 AM
BluFlame's Avatar
I'll replace the lower radiator hose, it looks like its leaking coolant into alternator. Mine is not in recall.
Old Jan 14, 2003 | 03:02 AM
Velcro's Avatar
it only took you two hours to do your alt, I did mine at 125k and it took me four I spent 1 hour trying to get it out without removing the radiator and and two and a half trying to get that ****ing bolt through(you know the one next to the block) maybe next time I'll get it quicker
Old Jan 14, 2003 | 10:29 AM
amb4081's Avatar
What else has to be removed to remove the alternator? What other components, I mean?
Old Jan 14, 2003 | 10:33 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Replaced alternator
i believe AC compressor needs to be moved over also.
Old Jan 14, 2003 | 12:09 PM
brodaiga's Avatar
Re: Re: Re: Replaced alternator
try installing with a SC in the way, a good 6-7 hour job
Old Jan 14, 2003 | 12:35 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Replaced alternator
been there...done that.
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
TheMafia
Sep 4, 2015 08:26 AM
