HELP!!!Problem w/ my rear door hinges!!!
Old Jan 14, 2003 | 06:10 AM
wordjb's Avatar
Can anyone help me? I have a 95 SE and both my rear door hinges are real tight and seem to be rubbing on something inside the door. Only started since the cold weather set in up here in Buffalo, NY. Checked it out and can't seem to find any obvious problem. So I lubricated the hinges with WD-40 but the problem persists. Got any ideas? Thanks for the help.
Old Jan 14, 2003 | 06:24 AM
mzmtg's Avatar
Minister of Silly Walks
WD40 is way too weak. Get some good grease for the hinges and the little bar.
Old Jan 14, 2003 | 07:26 AM
funnylittlman's Avatar
Re: HELP!!!Problem w/ my rear door hinges!!!
Use the white grease that nissan gobs on there w/ every 30 or 60K treatment... boy they gobbed like crazy for me....
Old Jan 14, 2003 | 08:08 AM
MajorMax96SE's Avatar
Re: Re: HELP!!!Problem w/ my rear door hinges!!!
I use WD40 and it works great for me. Just drench all the hinges in it and reapply it every so often.
Old Jan 14, 2003 | 10:09 AM
wordjb's Avatar
Do you by any chance know what that white goo is called and where i can get some of it for myself. Thanks alot
Old Jan 14, 2003 | 10:38 AM
Miasma's Avatar
white lithium grease is what i use, spray it on the hinge and be done.
Old Jan 14, 2003 | 10:53 AM
cscm094's Avatar
any regular old grease should work fine...
Old Jan 14, 2003 | 11:59 AM
Bernie Lomax's Avatar
This is a common problem. WD40 did nothing for me. I used the white grease, in a stick form, not the spray.
Old Jan 15, 2003 | 03:41 AM
Velcro's Avatar
I'm gonna have to agree WD-40 is more of a cleaner and penatrant than a lubricant. Go get some white lithium grease the spray will work but try to get something that is not and aerosol
Old Jan 15, 2003 | 05:55 AM
wordjb's Avatar
Thanks alot for all your help guys.
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
delerium75
Aug 19, 2015 11:08 AM
