Annoying humming sound while crusing??
Old Jan 14, 2003 | 02:17 PM
Grey00lustre's Avatar
sometimes when i'm driving low speed say 50 or so it makes this humming sound and goes away when i'm at higger speed...i already took it to a shop and put it on a jack but nothing was found wrong...anybody have this problem?
Old Jan 14, 2003 | 02:29 PM
NISMO808's Avatar
maybe your tires are noisy.
Old Jan 14, 2003 | 02:44 PM
i don't think so cause i just change my stock pontenza 17' with some nittos...and the stock ones also had the noise..i originally thought it was something grinding but shop didn't find anything..
Old Jan 14, 2003 | 04:02 PM
MIXXMAX's Avatar
Front wheel bearings?
Old Jan 14, 2003 | 04:30 PM
kmax's Avatar
I get a low pitched humming noise out of the rear on certain road surfaces and sometimes when the road is wet. I've had this since I've had my Max and have learned to live with it and consider it normal.
Hope this helps.
Old Jan 14, 2003 | 06:30 PM
Lime's Avatar
if it is actually groaning, does it occur when you left up on the brakes?
Old Jan 14, 2003 | 06:36 PM
Street Reeper's Avatar
Handsome
Re: Annoying humming sound while crusing??
Are you on the same roads when your going 50 as when your going at higher speeds. I have Nitto's too, and they are notorious for being loud. Mine are no exception. I really think it is your tires, and road conditions. I had the same thoughts once and couldn't find anything so I took the car in. Everything that would make that noise checked out fine.
But sometimes when I'm driving on the highway I will get this wierd very faint humming sound (sounds like the motor in your stereo when you eject a CD) that lasts about 2 seconds. I figure anything that doesn't give me a code is OK though. Unless it's that d@mn rattle on the drivers side where the ven number is underneath the front windsheiled, I have no idea how I will get to that, but I guess that's what you get after a while of having a noisy intake.
Mahmuth
Aug 16, 2024 08:23 PM
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
mpbclutch33
Dec 26, 2015 11:11 AM
