EGRC solenoid valve problem
Old Jan 16, 2003 | 07:08 PM
wintermhr301's Avatar
hey folks....my first time here.....does anyone know anything about an EGRC solenoid valve....i have no idea what and where it is at all...i ran the car computer after the check engine light lit up this morning and came up with code 10 05.....any input would definately be appreciated...thanx
Old Jan 16, 2003 | 07:21 PM
sebaxx's Avatar
its easy
at courtesyparts.com cost me 44 dollars is exactly on the left side of the transmision fluid check....if you are loking the car on the front is on the right....is a electic part that controls some funtions.....i saw the check engine light on...reset and check the code...is 1005 something like that...but you most remplace it...i recomend do in the dealer cause they have to control de vacumm and do others things to put it....some huys just put it but later it will be some problems i think
Old Jan 16, 2003 | 07:25 PM
Re: its easy
what is its function?
Old Jan 16, 2003 | 07:31 PM
Re: its easy
Old Jan 16, 2003 | 10:26 PM
sebaxx's Avatar
its works for
this sensor solenoid valve just check the intake pressure and ambient barometric pressure, changes resulting from changes in engine load and speed...its works with the egr system
this solenoid is connected with,
MAP sensor
Intake air duct
Intake manifold
Cavuum source
So is simple to remplace but you should have some tools to see the vacuum, pressure, etc...so for best result buy from courtesyparts.com, and go to your dealer....i think is cheap to do that.
trailer54
Nitrous
Nov 18, 2015 07:44 PM
tgreen
Oct 18, 2015 06:18 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
tardrex
Sep 11, 2015 07:35 PM
