Oil Question
Old Jan 16, 2003 | 09:03 PM
95CustomMaxima's Avatar
Oil Question
I had changed my oil about a month ago and have stored my car since then..I decided to take a look at the dipstick and it had showed that i had overfilled . The oil go over the H on the dipstick. Is this a problem or no? The Car hasnt been driven since the change. Thanks in advance.
L::::H* The * shows were the oil is on the dipstick..just above the H
-Nick
Old Jan 17, 2003 | 12:35 AM
karguy's Avatar
Re: Oil Question
-Nick
If it is just above the H on the dipstick I wouldn't worry about if it were my car. I have done that before and never had any problems.
Old Jan 17, 2003 | 04:17 AM
mrbill's Avatar
Re: Oil Question
-Nick
I have found that it does take a very long time for the oil to settle in the Max before you can get an accurate reading from the stick. When changing, I always put the recommended amount of oil in (4.5 quarts I think?) then maybe check the dip stick a couple of hours later. If you think you are more than a half quart over full, or if it's going to bother you until the next change, you can always remove the drain plug a let a bit run out. It's a bit messy on the hands but should only take a few minutes. I had to do that once when the "oil change place" put too much oil in.
Old Jan 17, 2003 | 04:57 AM
GreenSE's Avatar
have you started it?
Remember that once you start your car the oil will flow into the empty oil fiter and a portion will remain there after you turn the engine off again. Then you will have a little less oil in the pan.
Old Jan 17, 2003 | 08:21 AM
Max96's Avatar
Dont even worry about it......
Old Jan 17, 2003 | 11:30 AM
(_8*(l)Homer's Avatar
Old Jan 17, 2003 | 11:31 AM
Mar 12, 2020 12:06 AM
kjlouis
Oct 3, 2015 05:29 AM
ag90fox
Sep 9, 2015 12:22 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
