clutch pedal sticking ?
Old Jan 19, 2003 | 03:20 PM
bill4max's Avatar
i have a 97 5-speed and the other night when it was extremly cold out like 2 below i nioticed my clutch was acting funny. the pedal would return slowly compared to usual that went away when it warmed up but now the pedal will stick to the floor for a second and then pop all the way up only when pressed all the way down. My question is why is it doing this and how to fix it. Also i bled the system a month ago when i replaced the clutch and has worked fine untill 2 nights ago.
Old Jan 19, 2003 | 07:52 PM
tvn_1010's Avatar
Re: clutch pedal sticking ?
usually with the clutch being stuck, it generally mean you have air in your clutch system. you might want to try bleeding the clutch again. i believe there are 2 spots where the clutch can be bleed. trying bleeding both places. see site:
http://motorvate.ca/
under transmission for bleeding the upper and lower bleeder...good luck.
also, check your brake/clutch fluid to see what level it is at.
Old Jan 19, 2003 | 08:20 PM
boris's Avatar
Check the floor mat
Old Jan 19, 2003 | 08:36 PM
96BLUMAX's Avatar
Hopefully its just the hydraulics. I had my clutch installed recently and it is out of alignment so i have to take it back. That too will give you a bad pedal feel.
ef9
Oct 4, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
