Blower Motor Resistor Fixed/Question
Old Jan 20, 2003 | 06:30 AM
phid_bombadier's Avatar
So after doing some research on this forum/faqs, the problem with my gf's 98 Maxima (No 1, 2, 3 but 4 Ok) was the Blower Motor Resistor pack...really easy to get to, direcly above the passenger's right foot.
So I pulled the circuit board and clean up the traces. There is one single solder bridge/joint that had some corosion. I tested all paths with my DMM and determined hat this solder joint was the problem. I removed all the solder to verify that there was no components under all the corosion. There was none and I proceeded to drop a new bead of solder on the connection. Connectivity confirmed and I put it back in the car. Now everything is working again.
My question is, was the original solder joint set to fail at a certain shorting amperage or temperature? (Being that this is the ONLY solder joint on the board, everything else is a trace) I don't want to set myself up for a bigger problem if that thing catches on fire. The resitor board gets quite hot when in use.
EDIT: Just talked to an EE buddy. Looks like the solder joint was probably a fusable link (softer/lower temp solder). The main blower fuse should pick up the slack in case anything overloads though. (Basically a backup fuse as I understand it) 30 bucks saved...is 30 bucks saved!
Thanks.
--Mike
Old Jan 20, 2003 | 07:07 AM
mzmtg's Avatar
Minister of Silly Walks
Nice work. I added your fix to the FAQ.
Old Nov 30, 2004 | 03:28 PM
slag's Avatar
did this today, worked like a charm.
Thanks much, my local dealer charges $35.00 for this part.
Joe
Old Nov 30, 2004 | 03:55 PM
Terran's Avatar
Nice job!!!
Noobs who figure things out themselves (let alone read it in the faqs) are a rare breed.
Old Mar 18, 2007 | 06:58 PM
tong's Avatar
Excelent, worked like a charm, Mine was a 2 contact job though, should of taken a picture of the board. There was one on each side, resoldered them and works great, thanks.
Old Jul 15, 2007 | 04:33 PM
95BLKMAX's Avatar
W00h00! this worked for me as well. Did it last nite and it works FTW
Old Jul 15, 2007 | 06:12 PM
SVI30's Avatar
Thanks.
--Mike
The fuseable link reason is interesting.
Solder joints will fail. This happened to me on two cars already. One was the windshield wiper controller board in the engine compartment of my '94 Suburban. It is still working today. The other one was on the A/C controller board in a '91 Volvo 940 inside the passenger compartment.
The mechanism of failure is usually temperature cycling. The circuit board, pin and solder all have different temperature coefficient of expansion. So each time the circuit board is heated up and cool down, the joints will be under stress. The solder itself is suppose to be eutectic (semi-liquid) but the mixture used by the manufacturers may not be ideal (tin/lead/silver) so the joints would fail prematurely. The worst case are the larger pins.
The fan resistor assembly runs hot so it will be temperature cycled every time the A/C is started. My failed also but I haven't taken it apart yet.
Old Aug 8, 2007 | 09:51 PM
shell's Avatar
pics
I resoldered my blower resistor today -- thought i'd post pics:
Oxidized and broken:
Soldered and fixed:
Old Aug 9, 2007 | 06:43 AM
JtzMax's Avatar
Whatchyou say?
NICE !!!! Wish you would have posted this about 3 months ago! lol I had to replace mine ... $17 from Autozone ... but still, that's money and I have solder dang it!
Nice add to the FAQs ... keep the posts coming
Old Sep 25, 2007 | 09:12 AM
endus's Avatar
An atavistic endeavor...
I found this in search and it isn't that old so I'll ask here...
is the problem that this was fixing the blower motor not working at all, or was it that the motor was only blowing full blast/not at all. 4 is the only speed that works on mine right now, everything else is just off.
Old Sep 26, 2007 | 07:38 AM
lexoid's Avatar
It's a fix for a blower not blowing in 1,2,3 speeds, but only FULL.
Old Sep 26, 2007 | 08:03 AM
endus's Avatar
Perfect, yep, thats the problem. Thanks much...gotta bust out the soldering iron tonight.
Old Sep 26, 2007 | 12:21 PM
mrjamaica98mx's Avatar
just paid to get that done last week
Old Sep 27, 2007 | 04:14 PM
alex19's Avatar
hey i have a 95 maxima. everything used to work fyne then recently somtimes all the blower fans would stop working and then as the car ran it come bak. but now all the blower fans have stoped working. anyone have any idea on what may be the problem? i dont think my motor is blown out im guessing its somwhere in the electrical connection. any tips would be helpful thanks
ps. tried to locate the resistor but could not find.
Old Dec 30, 2007 | 03:25 PM
jordandalley's Avatar
tried this today. Didn't work for me. My circuit board tracks look completely different to yours though and the solder just didnt want to stick to the board.
Will probably have to get a new one.
Old Jan 9, 2008 | 05:18 PM
Did anyone find that once they soldered the board it got so hot it melted the solder off it? Happened to me. Ended up getting a new resistor out of an A33 - same part.
Old Feb 25, 2008 | 02:35 PM
gatsugansu's Avatar
Well this is what mine looks like. totally different from you guys'. can i wash with alcohol to remove corrosion? or soap water?
Old Feb 25, 2008 | 02:54 PM
MOHFpro90's Avatar
Rubbing alcohol will be fine.
Old Feb 25, 2008 | 07:30 PM
endus's Avatar
I should have mentioned...this was def the problem with mine. Thanks everyone for the help.
Old Feb 26, 2008 | 12:03 PM
gatsugansu's Avatar
when i tried to wash the corrosion the little strips came right off. i guess i need to buy new one.
Old Feb 26, 2008 | 09:45 PM
nafddur's Avatar
A new resistor frrom the dealer is only around $25, and only takes a few minutes to change.
Old Feb 27, 2008 | 02:46 PM
gatsugansu's Avatar
Actually dealer wants $36.28+tax.
Autozone wants $39.99+tax
Courtesyparts.com does not have it.
fanaticrockford $10. Works great!
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
