Whoa! Just peeled out with a 95 auto.
Old Jan 20, 2003 | 09:09 AM
Sir. Max's Avatar
I was coming out of a gas station waiting for traffic to clear when a small opening came up. I floored it to keep up with the speed of traffic. To my surprise the tires peeled for about 1 second. Is this normal for us auto's w/o boost?
By the way it was kind off cold outside.
Old Jan 20, 2003 | 09:14 AM
mzmtg's Avatar
Minister of Silly Walks
Um, no big deal. I can spin my tires any time I want...
Old Jan 20, 2003 | 09:18 AM
KLoWnPR109's Avatar
I can do what you did also, and I have 30 less hp than you and no top end
Cold will cause you to lose traction easier too I believe.
96BLUMAX's Avatar
Depends on your rims. When i was auto it was hard to peel out in my heavy 18s.
Old Jan 20, 2003 | 09:34 AM
Lime's Avatar
even more depends on your tires and tire pressure. I peel out all the darn time with the winter tires.
Old Jan 20, 2003 | 09:43 AM
blizz20oma's Avatar
I'm so hood
You can peel out in an automatic Geo Metro with 4 200lb people shoved in and the car turned to "Econ" mode.
OK, maybe not 4 people. But 3.
Old Jan 20, 2003 | 09:44 AM
Lime's Avatar
more depends on your tire pressure and type of tires. The winter tires I have peel if I do anything more than 1/4 throttle from a stop.
Old Jan 20, 2003 | 10:00 AM
Sir. Max's Avatar
That makes sense because i've tried a couple times with my aftermarket 17s with no luck. As soon as a I changed over to the stock wheels for winter, i've been chirping almost every time I take off hard.
Old Jan 20, 2003 | 10:03 AM
I30tMikeD's Avatar
Old Jan 20, 2003 | 10:11 AM
BBaker025's Avatar
Its not that hard, especially when u got stock rims and no tread left on ur tires
Old Jan 20, 2003 | 10:48 AM
maximaah's Avatar
Looking forward to spring so I can put on some wider tires and STOP doing this. Esp when you are leaning into a corner, the inside tire lifts and you can pretty much smoke 'em any time you want.
Old Jan 20, 2003 | 11:49 AM
MrEous's Avatar
^ Jeff™
It could also be the type of road you're on. Some parts of Dallas have these paved roads that you could lose traction with a bicycle.
(For those in the area, I mean the roads over by Malibu under I35)
Old Jan 20, 2003 | 12:14 PM
DTR Maxima's Avatar
when my car was stock i could peel out on stock tires, in the summer, its not a big deal, now that i have more mods i can break them loose and peel out at like 15mph in 1st gear
Old Jan 20, 2003 | 01:45 PM
nesquiknate's Avatar
if you take off while turning(from a stop)flooring it will almost smoke your tire all the way till 30mph for me.. i got new tires now so i no longer drive fast
Old Jan 20, 2003 | 05:53 PM
TitleistPrto's Avatar
Is it the higher the tire pressure the more you will peel out or the less tire pressure. I want to peel out sometimes and never can anymore because of the 18s and I dont know what else.
Old Jan 21, 2003 | 07:44 AM
maximaah's Avatar
Higher. Makes your tire "rounder" and less contact patch on the pavement. Converse is if you're stuck in snow/ice/mud, you let some air out of the tire to help you get more low-speed traction and out of the predicament (and of course add the air back when you're free)
I tend to slightly over-inflate my tires anyway for longer wear as the outside edges always seem to go first.
Old Jan 21, 2003 | 07:57 AM
clee130's Avatar
Peeling out is rather useless and wears out your tires.
But if you're going to do it ... at least do it with style:
I used to peel out in my 95 auto often too - but that was mostly due to my cheap worn tires.
Old Jan 21, 2003 | 08:44 AM
maximaah's Avatar
Uh, wait.
Old Jan 21, 2003 | 12:30 PM
AssyrianRacer
Hell yeah dude
Man my Max has TCS so basically if I turn it off I can peel out forever if I wanted,, I cant peel if its on though becuase i have limited slip transmission so it peels for a mili second then it kicks in and stops it.
Shift_ To Get Away From The Cops!
thatcollegestudent
18
Oct 5, 2015 02:29 PM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
sliptap
Sep 30, 2015 05:57 AM
Tmax78
Sep 25, 2015 09:07 PM
