Big brake kit
Old Jan 20, 2003 | 02:59 PM
speedemn's Avatar
Big brake kit
Are there any big brake kits out there that are usable with 16" rims? The reason I ask is because I have a set of SSR Type C rims that are 16x7 that I am contemplating on putting on come summer time. I wanted to keep the weight as low as possible so I thought 16" was a good compromize between looks and performance. However does that mean I'm screwed out of any big brake kit?
The other problem is that in the Winter I will be putting my stock 15" SE rims back on with snow tires... I assume that even if there is a big brake kit out there that will go under 16" rims, there isn't one that will also accomodate 15" rims?
Thanks for any advice.
Old Jan 20, 2003 | 03:02 PM
BBaker025's Avatar
No, if you want a big brake kit u need to have 17 in rims. You can get 300ZX tt brakes that fit with some modification.
Old Jan 20, 2003 | 03:29 PM
Pervis Anathema's Avatar
Doesn't Matt93SE have 16" with 12.2" rotors?
Old Jan 20, 2003 | 04:10 PM
DanSE's Avatar
Big brake kits cost BIG BUCKS. Just go with new rotors and pads, and if you got the cash get braided lines. I got the stillen rotors when they were on sale, and I recently bought a set of brand new calipers on ebay for $26. They are not SUPER high performance, but defenatly better than stock. And you dont have to modify anything, they will work with 16" and 15" rims.
Good luck,
Dan
Old Jan 20, 2003 | 04:14 PM
BBaker025's Avatar
What car are they off of? 300ZX?
Old Jan 20, 2003 | 05:36 PM
speedemn's Avatar
Does that mean that I cannot get 4-piston or 6-piston (or 8-piston ) calipers even if I get 300ZX rotors or aftermarket rotors?
Old Jan 20, 2003 | 06:16 PM
brianw's Avatar
A 12.2" diameter rotor kit might fit, depending on the calipers that you use and the particular fitment issues with the wheel design itself.
I don't know if the FastBrakes kit fits under 16" wheels at the moment.
Old Jan 20, 2003 | 06:20 PM
DanSE's Avatar
They are OEM calipers for 95-99 max's. Brand new.
Mar 12, 2020 12:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
