Cutting bumpstops with B&G springs
Old Jan 20, 2003 | 02:59 PM
heems27's Avatar
I'm putting my B&G springs in this weekend and I need to know how much I need to trim the bumpstops. Should I trim some of it off or hack off the whole thing? Any advice would be appreciated. By the way, I'm running KYB/GR2 struts/springs.
Thanks.
Old Jan 20, 2003 | 03:44 PM
96shogunmax's Avatar
Re: Cutting bumpstops with B&G springs
Thanks.
Good question, Im doing mine this coming up weekend. My guess is cut it half way off.
Old Jan 20, 2003 | 06:03 PM
njmaxseltd's Avatar
Cut 2 of the 3 rings on the fronts. The rear you need to trim quite a bit from as well. I suggest you use the motorvational mounts to give you some more travel in the rear as well. It makes a HUGE difference in the way your car rides with B&G's.
I ran those springs last summer for a while. I switched back to H&R's because NYC + B&G =
Old Jan 20, 2003 | 07:31 PM
BOZOnPJs's Avatar
Tom, do you have the web sight for the motorvational mounts?.. i know they are a bit pricy but well worth the money on the long run.
thanks.
Old Jan 21, 2003 | 06:02 AM
njmaxseltd's Avatar
http://www.motivational.net/products/shockmounts.shtml
magiconthetire
Oct 26, 2015 09:03 PM
MaxLvr21
Oct 17, 2015 12:11 PM
RealityCheck
Oct 2, 2015 06:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
